跳转到主内容
Astro A50 2016 Headset Speakers Replacement
你所需要的
  1. Astro A50 2016 Headset Speakers Replacement, Headset Speakers: 步骤 1 中的图像 1,2 Astro A50 2016 Headset Speakers Replacement, Headset Speakers: 步骤 1 中的图像 2,2
    • Remove the magnetic ear pads by gently pulling up away from the head set.
  2. Astro A50 2016 Headset Speakers Replacement: 步骤 2 中的图像 1,1
    • Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
  3. Astro A50 2016 Headset Speakers Replacement: 步骤 3 中的图像 1,1
    • Remove the four 6mm Phillips 1 screws.
  4. Astro A50 2016 Headset Speakers Replacement: 步骤 4 中的图像 1,1
    • Lift the speaker module up off the device.
结论
5等其他人完成本指南。
Vincent Seguin
于10/02/17注册
379 声望
创作了3篇指南
团队
Cal Poly, Team S15-G1, Livingston Fall 2017 Cal Poly, Team S15-G1, Livingston Fall 2017 的会员
CPSU-LIVINGSTON-F17S15G1
3 名成员
创作了10篇指南
5条评论
Great, pictures and explaining. But where do i get an speaker to replace the old one?
D3EW D - 回复
I am also looking for the replacement speakers. They seem impossible to find
Steven Fleck -
hola me encantaria que me pudieran decir donde comprar el repuesto de uno de los altavocez, porque no encuentro nada
ruben el gay - 回复
Awesome, but I don’t believe see anywhere on how to fix the mic as it rotates 360 free spinning rather than locking in the 90° talk and mute positions…?
Tippio - 回复
this is almost no solution, your cover is broken, there is stop on plastic cover.
X Pi Acoustic(CN) -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 26
总计 6,501
