跳转到主内容
Astro A50 2016 Headset Buttons Replacement
你所需要的
  1. Astro A50 2016 Headset Buttons Replacement, Headset Speakers: 步骤 1 中的图像 1,2 Astro A50 2016 Headset Buttons Replacement, Headset Speakers: 步骤 1 中的图像 2,2
    • Remove the magnetic ear pads by gently pulling up away from the head set.
  2. Astro A50 2016 Headset Buttons Replacement: 步骤 2 中的图像 1,1
    • Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
  3. Astro A50 2016 Headset Buttons Replacement: 步骤 3 中的图像 1,1
    • Remove the four 6mm Phillips 1 screws.
  4. Astro A50 2016 Headset Buttons Replacement: 步骤 4 中的图像 1,1
    • Lift the speaker module up off the device.
  5. Astro A50 2016 Headset Buttons Replacement, Headset Buttons: 步骤 5 中的图像 1,1
    • Remove the three 6mm PH1 screws.
  6. Astro A50 2016 Headset Buttons Replacement: 步骤 6 中的图像 1,1
    • Remove the four 6 mm PH1 screws.
  7. Astro A50 2016 Headset Buttons Replacement: 步骤 7 中的图像 1,1
    • Dettach the thin circuit board from the ribbon with your hand by pulling the board and wire in different directions.
  8. Astro A50 2016 Headset Buttons Replacement: 步骤 8 中的图像 1,1
    • Pull the two unscrewed buttons away from the ear cuffs with your hand.
  9. Astro A50 2016 Headset Buttons Replacement: 步骤 9 中的图像 1,1
    • Remove the two 6mm PH1 screws.
    • Pull the unscrewed button away from the ear cuffs with your hand.
  10. Astro A50 2016 Headset Buttons Replacement: 步骤 10 中的图像 1,2 Astro A50 2016 Headset Buttons Replacement: 步骤 10 中的图像 2,2
    • Use your hands to pull the volume wheel up and away from the device.
结论
另外一个人完成了本指南。
Vincent Seguin
于10/02/17注册
379 声望
创作了3篇指南
团队
Cal Poly, Team S15-G1, Livingston Fall 2017 Cal Poly, Team S15-G1, Livingston Fall 2017 的会员
CPSU-LIVINGSTON-F17S15G1
3 名成员
创作了10篇指南
2条评论
hola una pregunta saben donde consiguen la rueda de volumen ya que mis astro a50 de tercera generacion de xbox tiene un problema cuando le giras la rueda para subir el volumen y bajar el volumen ya que no funciona del todo bien, en pocas palabras no hace bien su funcion al regular el sonido al girar la rueda y quisiera reparar eso.
bryan200131 - 回复
Yo también tengo el mismo problema. He encontrado unas piezas similares en Ali express pero no sé si le queden a los astro a50. Son de la marca Logitech pero para los G933. La pieza se ve muy parecida. Para evitar problemas yo estoy buscando la placa de circuitos completa, pero no la he encontrado. Si sabes algo te agradecería lo compartieras
omar ramirez marin -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 27
总计 2,245
