跳转到主内容
Astro A50 2016 Base Station Motherboard Replacement
你所需要的
  1. Astro A50 2016 Base Station Motherboard Replacement, Base Station Motherboard: 步骤 1 中的图像 1,1
    • Remove the four rubber feet from the bottom of the base station using the plastic opening tool.
  2. Astro A50 2016 Base Station Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the ten 6 mm screws using a T8 screwdriver.
  3. Astro A50 2016 Base Station Motherboard Replacement: 步骤 3 中的图像 1,2 Astro A50 2016 Base Station Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove the four 6 mm screws using a T6 screwdriver.
    • Remove each metal plate by lodging the plastic opening tool underneath it and using your hands to lift the plate away from the device.
  4. Astro A50 2016 Base Station Motherboard Replacement: 步骤 4 中的图像 1,2 Astro A50 2016 Base Station Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use your hand to gently pull the green side plates away from the center of the device.
  5. Astro A50 2016 Base Station Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the six 6mm screws using a T6 screwdriver.
  6. Astro A50 2016 Base Station Motherboard Replacement: 步骤 6 中的图像 1,3 Astro A50 2016 Base Station Motherboard Replacement: 步骤 6 中的图像 2,3 Astro A50 2016 Base Station Motherboard Replacement: 步骤 6 中的图像 3,3
    • Lift up the motherboard from the base station and pull it away from the device to remove it.
结论
2等其他人完成本指南。
Vincent Seguin
于10/02/17注册
379 声望
创作了3篇指南
团队
Cal Poly, Team S15-G1, Livingston Fall 2017 Cal Poly, Team S15-G1, Livingston Fall 2017 的会员
CPSU-LIVINGSTON-F17S15G1
3 名成员
创作了10篇指南
5条评论
my base station dont turen on, the front leds. any solution?
edgar jesus cortez cosio - 回复
my base station dont turns on the front leds, any solution?
having the same problem {with the front LEDs not turning on or it not being recognized by pc}what does the white button on the base station motherboard do?
Devin Danimals - 回复
Where can I purchase one of these motherboards?
he-g-man-aftermath - 回复
I need a new base board any ideas where I may purchase one
Paul Bishop - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 18
过去 30 天: 88
总计 8,754
