跳转到主内容
Astro A40 TR Plus Mixamp M80 Headband Replacement
你所需要的
  1. Astro A40 TR Plus Mixamp M80 Headband Replacement, Headband Adjusters: 步骤 1 中的图像 1,3 Astro A40 TR Plus Mixamp M80 Headband Replacement, Headband Adjusters: 步骤 1 中的图像 2,3 Astro A40 TR Plus Mixamp M80 Headband Replacement, Headband Adjusters: 步骤 1 中的图像 3,3
    • Use a screwdriver with a H2.0 head to remove the two screws on the upper headband plate.
    • Use a screwdriver with a T9 bit to remove one screw from the upper headband plate.
    • Remove the upper headband plate.
    • Repeat the past three steps for the upper headband plate on the other side.
  2. Astro A40 TR Plus Mixamp M80 Headband Replacement: 步骤 2 中的图像 1,3 Astro A40 TR Plus Mixamp M80 Headband Replacement: 步骤 2 中的图像 2,3 Astro A40 TR Plus Mixamp M80 Headband Replacement: 步骤 2 中的图像 3,3
    • Use a screwdriver with a H2.0 head to remove the two screws on the lower headband plate.
    • Use a screwdriver with a T9 bit to remove one screw from the lower headband plate.
    • Remove the lower headband plate.
    • Repeat the past three steps for the lower headband plate on the other side.
  3. Astro A40 TR Plus Mixamp M80 Headband Replacement: 步骤 3 中的图像 1,1
    • Use your hand to remove the headband adjuster.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 27
总计 2,899
