跳转到主内容
Astro A40 TR Microphone Jack Replacement
你所需要的
  1. Astro A40 TR Microphone Jack  Replacement, Speakers: 步骤 1 中的图像 1,2 Astro A40 TR Microphone Jack  Replacement, Speakers: 步骤 1 中的图像 2,2
    • To access the speakers you need to disassemble the earpiece. First remove the foam ear piece by simply pinching the padding and pulling lightly until the magnets disengage.
  2. Astro A40 TR Microphone Jack  Replacement: 步骤 2 中的图像 1,3 Astro A40 TR Microphone Jack  Replacement: 步骤 2 中的图像 2,3 Astro A40 TR Microphone Jack  Replacement: 步骤 2 中的图像 3,3
    • Remove the dust cover located on the speaker. Use the corner of the spudger to peel underneath the cover until you can lift it by hand. The cover is held onto the device with adhesive and should be removed slowly.
  3. Astro A40 TR Microphone Jack  Replacement: 步骤 3 中的图像 1,2 Astro A40 TR Microphone Jack  Replacement: 步骤 3 中的图像 2,2
    • Take off the front cover by removing the four screws located in a square formation on the surface of the device. Use the J00 Philips driver listed in the device page.
  4. Astro A40 TR Microphone Jack  Replacement: 步骤 4 中的图像 1,2 Astro A40 TR Microphone Jack  Replacement: 步骤 4 中的图像 2,2
    • Locate the three small screws under the speaker. Use the J00 Philips Driver to remove them.
  5. Astro A40 TR Microphone Jack  Replacement: 步骤 5 中的图像 1,1
    • If your issue is asking for the complete replacement of the speaker or the motherboard, un-solder the old components and replace with new speaker by re-soldering.
    • Check out this useful guide on how to solder and desolder connections if soldering is new to you.
  6. Astro A40 TR Microphone Jack  Replacement, Microphone Jack: 步骤 6 中的图像 1,1
    • Remove the three screws in the photo with the J00 driver bit, and pull the headphone jack away from the assembly.
  7. Astro A40 TR Microphone Jack  Replacement: 步骤 7 中的图像 1,1
    • Un-solder the two wires circled, at this point the entire assembly can be removed from the speaker and the remainder of the device.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 6-5, Martin Fall 2016 UMass Dartmouth, Team 6-5, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S6G5
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 62
总计 8,512
