跳转到主内容
Astro A40 TR External Headband Replacement
你所需要的
  1. Astro A40 TR External Headband Replacement, External Headband: 步骤 1 中的图像 1,2 Astro A40 TR External Headband Replacement, External Headband: 步骤 1 中的图像 2,2
    • Remove two hex screws on each side to free and remove the base plate. Do each step for both sides.
  2. Astro A40 TR External Headband Replacement: 步骤 2 中的图像 1,2 Astro A40 TR External Headband Replacement: 步骤 2 中的图像 2,2
    • Pull apart earpiece assembly and the connecting headband piece.
  3. Astro A40 TR External Headband Replacement: 步骤 3 中的图像 1,2 Astro A40 TR External Headband Replacement: 步骤 3 中的图像 2,2
    • Gently pull the padding layer off of both ends using your hands.
  4. Astro A40 TR External Headband Replacement: 步骤 4 中的图像 1,3 Astro A40 TR External Headband Replacement: 步骤 4 中的图像 2,3 Astro A40 TR External Headband Replacement: 步骤 4 中的图像 3,3
    • Locate the black wiring and gently pull it out of the plastic headpiece component.
结论
2等其他人完成本指南。
Mike
于10/20/16注册
448 声望
创作了3篇指南
团队
UMass Dartmouth, Team 6-5, Martin Fall 2016 UMass Dartmouth, Team 6-5, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S6G5
3 名成员
创作了10篇指南
6条评论
Is there any place you can purchase a new external headband? The part that holds the foam piece in place broke on mine yesterday :(
zironyy - 回复
i dont have the screws i lost them when i dropped my headset
Sniping_Ninja10 - 回复
Did you buy screws? I need as well but I don’t know which one is good!
photo -
Where Can I buy screws for? I know the size is T8 but how long? which one is good for? Please help me
photo - 回复
where can i buy a new headband
Dewis Polonia - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 71
总计 13,633
