简介
In this step we will be removing all parts necessary to reach the speaker inside each headset. Remember that you can repeat these same steps for each side of the headset if either side needs replacement.
你所需要的
Pull one corner of the pad to release it from the headset.
Pull the rest of the ear pad off.
Locate the four 4.5 mm Philips #0 screws on the panel shown.
Remove them using a Phillips #0 head screwdriver.
Remove the panel.
另外一个人完成了本指南。
2条评论
Where do you buy the replacement speaker ? Thanks.
what speakers can these be replaced with? this guide is a little short on details about the actual removal and replacement of the speakers. the information here is just the start
