跳转到主内容
Astro A40 Gen2 Speaker Replacement
你所需要的
  1. Astro A40 Gen2 Speaker Replacement, Ear Pad: 步骤 1 中的图像 1,2 Astro A40 Gen2 Speaker Replacement, Ear Pad: 步骤 1 中的图像 2,2
    • Pull one corner of the pad to release it from the headset.
    • Pull the rest of the ear pad off.
  2. Astro A40 Gen2 Speaker Replacement, Speaker: 步骤 2 中的图像 1,2 Astro A40 Gen2 Speaker Replacement, Speaker: 步骤 2 中的图像 2,2
    • Locate the four 4.5 mm Philips #0 screws on the panel shown.
    • Remove them using a Phillips #0 head screwdriver.
    • Remove the panel.
  3. Astro A40 Gen2 Speaker Replacement: 步骤 3 中的图像 1,2 Astro A40 Gen2 Speaker Replacement: 步骤 3 中的图像 2,2
    • Using either your fingers or a plastic opening tool, pry off the speaker cover.
  4. Astro A40 Gen2 Speaker Replacement: 步骤 4 中的图像 1,1
    • Locate the four 4.5 mm Philips #0 screws as shown on the speaker housing.
    • Remove the four screws using a Phillips #0 head screwdriver.
  5. Astro A40 Gen2 Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the housing to reveal the speaker.
    • Make sure not to break the small wire holding the two portions together.
结论
另外一个人完成了本指南。
Donavan Feliz
于01/22/15注册
444 声望
创作了2篇指南
团队
Cal Poly, Team 20-18, Maness Winter 2015 Cal Poly, Team 20-18, Maness Winter 2015 的会员
CPSU-MANESS-W15S20G18
4 名成员
创作了10篇指南
2条评论
Where do you buy the replacement speaker ? Thanks.
Steve Rosam - 回复
what speakers can these be replaced with? this guide is a little short on details about the actual removal and replacement of the speakers. the information here is just the start
Jasper W (Spike229) - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 4,454
