跳转到主内容
修复你的物品
维修的权力
商店
简介
In this guide, we will be reaching and removing the motherboard from its housing in the Astro A40 Gen2. The motherboard is the only component inside the mixamp.
WARNING: Use caution when placing screws to the side as they are very small and easy to lose. Place them in groups apart from each other to avoid confusion.
  1. Remove the dials using either a metal spudger or your hands.  Be careful as the dials may be difficult to remove. Remove the dials using either a metal spudger or your hands.  Be careful as the dials may be difficult to remove. Remove the dials using either a metal spudger or your hands.  Be careful as the dials may be difficult to remove.
    • Remove the dials using either a metal spudger or your hands. Be careful as the dials may be difficult to remove.
  2. Locate the two 11/32 inch nuts underneath the dials.
    • Locate the two 11/32 inch nuts underneath the dials.
    • Use an 11/32 inch socket wrench or tweezers to unscrew and remove the nuts and washers.
  3. Using a larger metal spudger, remove the rubber back of the mixamp. The back will have glue residue after removal.  Depending on the stickiness of the residue, more glue may be needed to stick the backing back on.
    • Using a larger metal spudger, remove the rubber back of the mixamp.
    • The back will have glue residue after removal. Depending on the stickiness of the residue, more glue may be needed to stick the backing back on.
  4. Remove the one 4.5 mm Phillips #0 screw on the back panel of the mixamp.
    • Remove the one 4.5 mm Phillips #0 screw on the back panel of the mixamp.
  5. Using a large metal spudger, detach all plastic clips holding the bottom and top casings together. Remove the input casing using your fingers. Be careful when releasing the clips between the two casings, as it is very easy to scratch the mixamp or break the clips.
    • Using a large metal spudger, detach all plastic clips holding the bottom and top casings together.
    • Remove the input casing using your fingers.
    • Be careful when releasing the clips between the two casings, as it is very easy to scratch the mixamp or break the clips.
    • Use caution when pulling the two casings apart as it is very easy to pinch your fingers between them.
  6. Remove the four 5.8 mm Phillips #0 screws on the motherboard.
    • Remove the four 5.8 mm Phillips #0 screws on the motherboard.
  7. Remove the motherboard from the casing. Remove the motherboard from the casing.
    • Remove the motherboard from the casing.
结论
另外一个人完成了本指南。
Mark
于2015年01月22日注册
376 信誉积分
创作了3篇指南
团队
Cal Poly, Team 20-18, Maness Winter 2015 Cal Poly, Team 20-18, Maness Winter 2015 的会员
CPSU-MANESS-W15S20G18
4 名成员
创作了5篇指南
Where would I find a motherboard? And would it save money fixing the mixamp?
benaiah paul - 回复
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 30
过去的30天: 118
总计 6,361
