跳转到主内容
Astro A40 Gen2 Mixamp Button Replacement
你所需要的
  1. Astro A40 Gen2 Mixamp Button Replacement, Remove Dials: 步骤 1 中的图像 1,3 Astro A40 Gen2 Mixamp Button Replacement, Remove Dials: 步骤 1 中的图像 2,3 Astro A40 Gen2 Mixamp Button Replacement, Remove Dials: 步骤 1 中的图像 3,3
    • Remove the dials using either a metal spudger or your hands. Be careful as the dials may be difficult to remove.
  2. Astro A40 Gen2 Mixamp Button Replacement, Remove nuts and washers.: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    • Locate the two 11/32 inch nuts underneath the dials.
    • Use an 11/32 inch socket wrench or tweezers to unscrew and remove the nuts and washers.
  3. Astro A40 Gen2 Mixamp Button Replacement, Remove back pad.: 步骤 3 中的图像 1,2 Astro A40 Gen2 Mixamp Button Replacement, Remove back pad.: 步骤 3 中的图像 2,2
    • Using a larger metal spudger, remove the rubber back of the mixamp.
    • The back will have glue residue after removal. Depending on the stickiness of the residue, more glue may be needed to stick the backing back on.
  4. Astro A40 Gen2 Mixamp Button Replacement, Take out main case screw.: 步骤 4 中的图像 1,1
    • Remove the one 4.5 mm Phillips #0 screw on the back panel of the mixamp.
  5. Astro A40 Gen2 Mixamp Button Replacement, Pry open the case.: 步骤 5 中的图像 1,3 Astro A40 Gen2 Mixamp Button Replacement, Pry open the case.: 步骤 5 中的图像 2,3 Astro A40 Gen2 Mixamp Button Replacement, Pry open the case.: 步骤 5 中的图像 3,3
    • Using a large metal spudger, detach all plastic clips holding the bottom and top casings together.
    • Remove the input casing using your fingers.
    • Be careful when releasing the clips between the two casings, as it is very easy to scratch the mixamp or break the clips.
    • Use caution when pulling the two casings apart as it is very easy to pinch your fingers between them.
  6. Astro A40 Gen2 Mixamp Button Replacement, Remove the motherboard from the case.: 步骤 6 中的图像 1,1
    • Remove the four 5.8 mm Phillips #0 screws on the motherboard.
  7. Astro A40 Gen2 Mixamp Button Replacement: 步骤 7 中的图像 1,2 Astro A40 Gen2 Mixamp Button Replacement: 步骤 7 中的图像 2,2
    • Remove the motherboard from the casing.
  8. Astro A40 Gen2 Mixamp Button Replacement, Mixamp Button: 步骤 8 中的图像 1,2 Astro A40 Gen2 Mixamp Button Replacement, Mixamp Button: 步骤 8 中的图像 2,2
    • Use a metal spudger to pry off the buttons and remove them.
    • You may need to apply pressure to break off the small black caps which hold the buttons down. The buttons will still function without the black caps.
结论
3等其他人完成本指南。
Mark
于01/22/15注册
412 声望
创作了3篇指南
团队
Cal Poly, Team 20-18, Maness Winter 2015 Cal Poly, Team 20-18, Maness Winter 2015 的会员
CPSU-MANESS-W15S20G18
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 22
总计 2,486
