跳转到主内容
修复你的物品
维修的权力
商店
简介
A stand created by three legs is a common method of supporting a load.
工具
配件
没有特定配件。
  1. Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side. Be sure the flat side of each tripod leg is facing toward the ground.
    • Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
    • Be sure the flat side of each tripod leg is facing toward the ground.
  2. 打开所有标签
    Mac的RAM升级套装
    购买套装
    所有选项卡都有足够的 RAM
    购买套装
  3. Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
    • Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
结论
To disassemble your device, follow these instructions in reverse order.
另外一个人完成了本指南。
Ashlie Reott
于2013年10月20日注册
328 信誉积分
创作了3篇指南
团队
Cal Poly, Team 4-30, Amido Fall 2013 Cal Poly, Team 4-30, Amido Fall 2013 的会员
CPSU-AMIDO-F13S4G30
4 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 508
