简介
This is a guide showing you how to disassemble and clean the Arturia MiniLab 3 keyboard keys. Due to negligence or accidental circumstance, it’s possible for one or more keys to get jammed which can prevent the user from creating sounds that they want. Following along this guide you will be able to fix your keys, bringing them back to use by yourself. You can also use this guide to replace the main PCB/motherboard in the Arturia MiniLab 3.
Before using this guide, make sure the issue you encountered is not caused by a broken USB cord by testing with other cords.
你所需要的
Remove the twelve 3 mm black Phillips #1 screws on the back of the keyboard using the Phillips #1 screwdriver.
Remove the eight 1.5 mm black Phillips #000 screws on the back of the keyboard using the Phillips #000 screwdriver.
