跳转到主内容
Arturia Microbrute Opening Procedure
你所需要的
  1. Arturia Microbrute Opening Procedure, Arturia Microbrute Opening Procedure: 步骤 1 中的图像 1,2 Arturia Microbrute Opening Procedure, Arturia Microbrute Opening Procedure: 步骤 1 中的图像 2,2
    • Switch off the Microbrute and make sure to disconnect any cables.
    • Don’t forget the mini patch bay on the top right.
  2. Arturia Microbrute Opening Procedure: 步骤 2 中的图像 1,1
    • Flip the Microbrute over and put it on a soft surface to not damage the knobs and faders.
    • Use a screwdriver to remove the twelve Philips screws on the bottom plate.
  3. Arturia Microbrute Opening Procedure: 步骤 3 中的图像 1,3 Arturia Microbrute Opening Procedure: 步骤 3 中的图像 2,3 Arturia Microbrute Opening Procedure: 步骤 3 中的图像 3,3
    • Put the Microbrute on its front edge and carefully tilt open the bottom plate including the keyboard.
    • Be aware of the ribbon cable connecting the keyboard to the PCB.
    • The cable should give you enough slack to put the top section over the keyboard section for better handling.
  4. Arturia Microbrute Opening Procedure: 步骤 4 中的图像 1,1
    • Next, focus on the connector of the keyboard.
  5. Arturia Microbrute Opening Procedure: 步骤 5 中的图像 1,3 Arturia Microbrute Opening Procedure: 步骤 5 中的图像 2,3 Arturia Microbrute Opening Procedure: 步骤 5 中的图像 3,3
    • Use a spudger to unlock the connector by pushing both left and right locking tabs tabs towards the cable.
  6. Arturia Microbrute Opening Procedure: 步骤 6 中的图像 1,2 Arturia Microbrute Opening Procedure: 步骤 6 中的图像 2,2
    • Grab the ribbon cable with your fingers and pull it out of the connector.
  7. Arturia Microbrute Opening Procedure: 步骤 7 中的图像 1,1
    • Now the Microbrute is open and the bottom plate with the keyboard is separated from the rest of the device.
结论
Tobias Isakeit
于03/31/14注册
118,415 声望
创作了189篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,089篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 28
总计 28
