此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
转到步骤 1 ↓仅当你完全确定 Aroma ARC-914SBD 电饭煲的电源线严重损坏且需要更换时,才应使用本更换指南。电源线位于设备的最底部。因此,在更换电源线之前,你需要先拆除几乎所有其他组件。在找到电源线后,最必要的工具之一是钳子。
你所需要的
工具
要重新组装设备,请按相反顺序执行这些说明。
2指南评论
I have ARC 5000SB - wanted to use this in India under 220V. Tried removing to see if I can attach voltage transformer in control circuit .. I am pretty sure no issue to heater. But couldn’t open fully … some wires are attached to lid and not possible to open upper plastic rim to access bottom circuit… any suggestions
Yeah, we had a lot of trouble opening it, we had to pry off the plastic from the metal to get access to those wires. It will break a few plastic tabs that hold it firmly in the metal ring. These really as we found serve no function other than preventing you from opening the cooker. It just is a hassle to get open so that you can work on these wires.
