跳转到主内容
加入维修社区 - 创建账户
Arnova 7K G3 Rubber Feet Replacement
你所需要的
    1. Arnova 7K G3 Rubber Feet Replacement, Rear Cover: 步骤 1 中的图像 1,3 Arnova 7K G3 Rubber Feet Replacement, Rear Cover: 步骤 1 中的图像 2,3 Arnova 7K G3 Rubber Feet Replacement, Rear Cover: 步骤 1 中的图像 3,3
      • Remove four 5 mm Phillips #00 screws from each corner of the tablet.
      询问修复机器人
      添加评论
    2. Arnova 7K G3 Rubber Feet Replacement: 步骤 2 中的图像 1,2 Arnova 7K G3 Rubber Feet Replacement: 步骤 2 中的图像 2,2
      • Place the iFixit opening tool in the notches between the cases and pull the covers apart.
      询问修复机器人
      添加评论
    3. Arnova 7K G3 Rubber Feet Replacement: 步骤 3 中的图像 1,1
      • Repeat step two until 3/4 of the rear cover is unlatched.
      • Proceed to remove the rear cover by gently pulling it apart by hand.
      询问修复机器人
      添加评论
    1. Arnova 7K G3 Rubber Feet Replacement, Rubber Feet: 步骤 4 中的图像 1,2 Arnova 7K G3 Rubber Feet Replacement, Rubber Feet: 步骤 4 中的图像 2,2
      • Locate the two lower bumpers on the back cover. These are the rubber feet.
      • Flip the cover over to reveal the inside.
      • Locate the two rubber tabs, there are two for each rubber foot. They are located on the inside of the cover.
      询问修复机器人
      添加评论
    2. Arnova 7K G3 Rubber Feet Replacement: 步骤 5 中的图像 1,1
      • Push the two tabs on each foot down using the pointed end of a spudger.
      • It may take some force to push in the tabs. Prying with the pointed end of the spudger and wiggling the tab free may be necessary.
      询问修复机器人
      添加评论
    3. Arnova 7K G3 Rubber Feet Replacement: 步骤 6 中的图像 1,1
      • Flip the cover back over so you see the outside. Remove the rubber feet if they have not already fallen out.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order with the new rubber feet.
取消:我没有完成这个指南。
团队
Michigan Tech, Team 1-2, Lauer Spring 2015 Michigan Tech, Team 1-2, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G2
2 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 25
总计 446
