跳转到主内容
Arnova 7K G3 Rubber Feet Replacement
你所需要的
  1. Arnova 7K G3 Rubber Feet Replacement, Rear Cover: 步骤 1 中的图像 1,3 Arnova 7K G3 Rubber Feet Replacement, Rear Cover: 步骤 1 中的图像 2,3 Arnova 7K G3 Rubber Feet Replacement, Rear Cover: 步骤 1 中的图像 3,3
    • Remove four 5 mm Phillips #00 screws from each corner of the tablet.
  2. Arnova 7K G3 Rubber Feet Replacement: 步骤 2 中的图像 1,2 Arnova 7K G3 Rubber Feet Replacement: 步骤 2 中的图像 2,2
    • Place the iFixit opening tool in the notches between the cases and pull the covers apart.
  3. Arnova 7K G3 Rubber Feet Replacement: 步骤 3 中的图像 1,1
    • Repeat step two until 3/4 of the rear cover is unlatched.
    • Proceed to remove the rear cover by gently pulling it apart by hand.
  4. Arnova 7K G3 Rubber Feet Replacement, Rubber Feet: 步骤 4 中的图像 1,2 Arnova 7K G3 Rubber Feet Replacement, Rubber Feet: 步骤 4 中的图像 2,2
    • Locate the two lower bumpers on the back cover. These are the rubber feet.
    • Flip the cover over to reveal the inside.
    • Locate the two rubber tabs, there are two for each rubber foot. They are located on the inside of the cover.
  5. Arnova 7K G3 Rubber Feet Replacement: 步骤 5 中的图像 1,1
    • Push the two tabs on each foot down using the pointed end of a spudger.
    • It may take some force to push in the tabs. Prying with the pointed end of the spudger and wiggling the tab free may be necessary.
  6. Arnova 7K G3 Rubber Feet Replacement: 步骤 6 中的图像 1,1
    • Flip the cover back over so you see the outside. Remove the rubber feet if they have not already fallen out.
结论
To reassemble your device, follow these instructions in reverse order with the new rubber feet.
Tyler Sigafoose
于03/19/15注册
210 声望
创作了2篇指南
团队
Michigan Tech, Team 1-2, Lauer Spring 2015 Michigan Tech, Team 1-2, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G2
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 177
