跳转到主内容
Armani Exchange AX1017 Lens Replacement
你所需要的
  1. Armani Exchange AX1017 Lens  Replacement, Glasses Lens: 步骤 1 中的图像 1,2 Armani Exchange AX1017 Lens  Replacement, Glasses Lens: 步骤 1 中的图像 2,2
    • Clean the outer frame of the glasses with a clean cloth.
  2. Armani Exchange AX1017 Lens  Replacement: 步骤 2 中的图像 1,2 Armani Exchange AX1017 Lens  Replacement: 步骤 2 中的图像 2,2
    • Remove the screw between the lens and the frame using the glasses repair kit's Phillips-head screwdriver.
  3. Armani Exchange AX1017 Lens  Replacement: 步骤 3 中的图像 1,2 Armani Exchange AX1017 Lens  Replacement: 步骤 3 中的图像 2,2
    • Carefully remove the damaged lens from the unscrewed frame.
  4. Armani Exchange AX1017 Lens  Replacement: 步骤 4 中的图像 1,1
    • Once removed, take a damp cloth (a cloth soaked in rubbing alcohol is preferred for the best clean) and clean inside of frame.
  5. Armani Exchange AX1017 Lens  Replacement: 步骤 5 中的图像 1,2 Armani Exchange AX1017 Lens  Replacement: 步骤 5 中的图像 2,2
    • Take your new lens and place it carefully into the frame. Make sure that the lens is slotted correctly into the frame, aligning the edges on the lens and the frame.
  6. Armani Exchange AX1017 Lens  Replacement: 步骤 6 中的图像 1,1
    • Screw the frame back together using the Phillips head screwdriver, ensuring that the new lens is slotted correctly into the frame.
结论
The guide gives complete instructions on removing, replacing, and returning the glasses back to their original state.
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 64
总计 1,677
