当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Lay your tablet upwards facing you.
Using the opening tool, begin by prying the tablet starting in the top left corner. This can be found near the volume and power buttons.
Begin to work your way around the tablet in a clockwise motion to separate the screen from the cover.
Once you have opened the screen, you will see two cables that connect the screen and the interior of the tablet.
Remove the white tab located on the right side of the interior by removing the tape and plug that connects it to the tab.
On the left side of the tablet, you will see a silver cable connecting the screen to the motherboard.
Using the tweezers, remove the black tape that is connecting the cable and screen. This will allow the gold connector to come loose.
The screen should be separated from the tablet.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
