跳转到主内容
Archos 97 Carbon Display Screen Replacement
你所需要的
  1. Archos 97 Carbon Display Screen Replacement, Removing the old cover from tablet: 步骤 1 中的图像 1,2 Archos 97 Carbon Display Screen Replacement, Removing the old cover from tablet: 步骤 1 中的图像 2,2
    • Lay your tablet upwards facing you.
    • Using the opening tool, begin by prying the tablet starting in the top left corner. This can be found near the volume and power buttons.
    • Begin to work your way around the tablet in a clockwise motion to separate the screen from the cover.
  2. Archos 97 Carbon Display Screen Replacement, Removing the white tab from tablet: 步骤 2 中的图像 1,3 Archos 97 Carbon Display Screen Replacement, Removing the white tab from tablet: 步骤 2 中的图像 2,3 Archos 97 Carbon Display Screen Replacement, Removing the white tab from tablet: 步骤 2 中的图像 3,3
    • Once you have opened the screen, you will see two cables that connect the screen and the interior of the tablet.
    • Remove the white tab located on the right side of the interior by removing the tape and plug that connects it to the tab.
  3. Archos 97 Carbon Display Screen Replacement, Removing the black tape from the tablet: 步骤 3 中的图像 1,2 Archos 97 Carbon Display Screen Replacement, Removing the black tape from the tablet: 步骤 3 中的图像 2,2
    • On the left side of the tablet, you will see a silver cable connecting the screen to the motherboard.
    • Using the tweezers, remove the black tape that is connecting the cable and screen. This will allow the gold connector to come loose.
    • The screen should be separated from the tablet.
  4. Archos 97 Carbon Display Screen Replacement, Removing the screws: 步骤 4 中的图像 1,2 Archos 97 Carbon Display Screen Replacement, Removing the screws: 步骤 4 中的图像 2,2
    • Remove the screws on the backside of the screen using a screwdriver.
    • There are four screws; one is covered by tape.
  5. Archos 97 Carbon Display Screen Replacement, Removing screen from frame: 步骤 5 中的图像 1,3 Archos 97 Carbon Display Screen Replacement, Removing screen from frame: 步骤 5 中的图像 2,3 Archos 97 Carbon Display Screen Replacement, Removing screen from frame: 步骤 5 中的图像 3,3
    • Gently pry the screen from the black frame that surrounds it using the opening tool.
    • Work in a clockwise motion until the screen is detached from the frame.
结论
2等其他人完成本指南。
Allyson Seber
于03/03/15注册
311 声望
创作了2篇指南
团队
一条评论
Hi,
Is this similar to replacing the touch screen on the Archos 101B model?.
colin - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,574
