跳转到主内容
Archos 97 Carbon Battery Replacement
你所需要的
  1. Archos 97 Carbon Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Pry open the tablet by having the tablet face upward. To pry open, start over in the left corner (by the buttons) working clockwise until the tablet is open.
  2. Archos 97 Carbon Battery Replacement: 步骤 2 中的图像 1,2 Archos 97 Carbon Battery Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Once the screen is separated from the back panel, you will see two cables connecting the screen to the interior of the tablet (one silver, one black)
    • Remove the black tape that is holding the end of the black cable to the white tab.
    • Gently pull the cable away from the tab with tweezers disconnecting the plug from the outlet.
  3. Archos 97 Carbon Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the silver cable by removing the tape that connects the cable and screen. Gently detach the gold cable from the outlet.
  4. Archos 97 Carbon Battery Replacement: 步骤 4 中的图像 1,2 Archos 97 Carbon Battery Replacement: 步骤 4 中的图像 2,2
    • Now the interior of the tablet is fully accessible.
    • Heat the soldering gun until it is fully heated. Place the tip of the soldering gun over the solder that seals the red and black battery cables to the motherboard. Once the solder is heated the cables can be removed.
结论
3等其他人完成本指南。
Kirsti McCarty
于03/03/15注册
110 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 3,882
