跳转到主内容
Archos 101 G9 Battery Replacement
你所需要的
  1. Archos 101 G9 Battery Replacement, Display Assembly: 步骤 1 中的图像 1,1
    • Place an iFixit opening tool in the crease where the display assembly and back of the device meet.
    • Slide the tool firmly through the crease on one side of the device, twisting as you go to create separation.
    • When you reach the corner, carefully pry the two halves of the device apart.
    • There are small clips along the edges that need to stay intact in order to properly reassemble the device. Be very gentle when prying so as not to break the clips.
    • Repeat for the remaining three sides and corners.
  2. Archos 101 G9 Battery Replacement: 步骤 2 中的图像 1,2 Archos 101 G9 Battery Replacement: 步骤 2 中的图像 2,2
    • Separate the halves of the device.
    • Ensure that you separate from the top and you keep the bottoms of both pieces near each other so as not to damage the ribbon cables that connect the halves.
  3. Archos 101 G9 Battery Replacement: 步骤 3 中的图像 1,2 Archos 101 G9 Battery Replacement: 步骤 3 中的图像 2,2
    • Gently remove both ribbon cables from their sockets on the motherboard.
  4. Archos 101 G9 Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the white and black coaxial cables with gold tips from the motherboard.
  5. Archos 101 G9 Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the display assembly from the back panel.
  6. Archos 101 G9 Battery Replacement, Battery: 步骤 6 中的图像 1,1
    • Remove the tape covering the solder connections on the motherboard.
  7. Archos 101 G9 Battery Replacement: 步骤 7 中的图像 1,1
    • Desolder the BATT+ connection from the motherboard.
    • Desolder the BATT- connection from the motherboard.
    • Desolder the NTC+ connection from the motherboard.
    • Desolder the NTC- connection from the motherboard.
    • Proceed with caution when using the soldering iron. Try not to damage the connections on the motherboard.
  8. Archos 101 G9 Battery Replacement: 步骤 8 中的图像 1,1
    • Remove the black tape from the top of each battery.
  9. Archos 101 G9 Battery Replacement: 步骤 9 中的图像 1,1
    • Remove the yellow tape from the batteries.
  10. Archos 101 G9 Battery Replacement: 步骤 10 中的图像 1,1
    • Gently pry the batteries away from the case using a nylon spudger.
    • Be very careful not to bend the batteries excessively while doing this.
    • Metal prying tools and other sharp objects may puncture the battery, potentially causing a fire. Always use plastic or nylon prying tools near the battery.
结论
Clay Meunier
于10/28/21注册
557 声望
创作了4篇指南
团队
UMass Dartmouth, Team 4-1, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-1, Gulbrandsen Fall 2021 的会员
UMASSD-GULBRANDSEN-F21S4G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 28
总计 845
