跳转到主内容
加入维修社区 - 创建账户
Aranet 4 Display Replacement
你所需要的
  1. Aranet 4 Display Replacement, Disassembly: 步骤 1 中的图像 1,2 Aranet 4 Display Replacement, Disassembly: 步骤 1 中的图像 2,2
    • Remove the battery door and the batteries.
    • Unscrew the two T6 screws.
    • Turn your device over so that the screen faces you and remove the cover.
  2. Aranet 4 Display Replacement, Removing the old screen: 步骤 2 中的图像 1,3 Aranet 4 Display Replacement, Removing the old screen: 步骤 2 中的图像 2,3 Aranet 4 Display Replacement, Removing the old screen: 步骤 2 中的图像 3,3
    • Pull back the screen.
    • Carefully release the display ribbon cable by, depending on your board revision either lifting the brown cover on the flip-up connector or sliding out the stuffer actuator connector. (Refer to the images for clarification.)
    • Remove the old screen.
  3. Aranet 4 Display Replacement, Placing new screen: 步骤 3 中的图像 1,1
    • Insert the new screen's cable into the connector (black side up).
    • Carefully place the front cover back and reassemble the device.
结论
It is not necessary to remove the the board from the bottom-case, if you do wish to do this be carefull not to break the battery terminals!
2等其他人完成本指南。
spoofer
于06/11/24注册
137 声望
撰写一个指南
8指南评论
Great info and instruction. But….. amazone does not ship to The Netherlands.
Cees Doets - 回复
Hi Cees,
You can look for products sold on amazon in different countries using the ASIN number.
Here's a link for the Netherlands: https://www.amazon.nl/dp/B071HW4Z6N
Good luck with your repair!
spoofer -
Thanks a lot! Great info.
Cees Doets - 回复
Yes yes yes. Both my Aranet’s work again.
Cees Doets - 回复
Thanks for the guide! I successfully repaired my Aranet4 by following it. A couple of notes:
- I was able to get a better price than Amazon for the replacement display at https://www.waveshare.com/product/displa....
- The connector for the flexible printed circuit board on my model didn't flip up, but instead slides forward. I found documentation for the connector (or something very very similar to it) here: https://www.te.com/content/dam/te-com/do... (search for "Stuffer Actuator (Plunger Style)")
Jon Manning - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 14
过去 30 天: 49
总计 564
