跳转到主内容
Aquarium CO2 System Replacement
你所需要的
  1. Aquarium CO2 System Replacement, CO2 System: 步骤 1 中的图像 1,1
    • Using the funnel, pour 1 teaspoon of baking soda, 7 tablespoons of sugar, 2 cups of lukewarm water, and 2 teaspoons of yeast into the 2L empty bottle.
  2. Aquarium CO2 System Replacement: 步骤 2 中的图像 1,1
    • Close the bottle.
    • Shake the bottle rapidly for 15 seconds (or until the liquid has turned milky-white).
  3. Aquarium CO2 System Replacement: 步骤 3 中的图像 1,3 Aquarium CO2 System Replacement: 步骤 3 中的图像 2,3 Aquarium CO2 System Replacement: 步骤 3 中的图像 3,3
    • Poke, drill, or cut a small hole in a 2L bottle cap and insert an airline tubing adaptor.
    • Use some kind of glue or sealant to seal the top of the bottle cap, ensuring an airtight fit.
    • Connect one end of the airline tubing to the airline tubing adapter, and the other end of the airline tubing to the CO2 diffuser.
  4. Aquarium CO2 System Replacement: 步骤 4 中的图像 1,1
    • Seal the bottle with the airline tubing adapter by screwing it onto the top of bottle's open lid.
  5. Aquarium CO2 System Replacement: 步骤 5 中的图像 1,1
    • Place the CO2 diffuser on the inside of the aquarium tank at below half-depth of the water-level.
    • Most CO2 diffusers are able to be stuck to the inside glass of the tank to achieve stronger stability.
    • Make sure the bottle is not placed too far away from the aquarium tank as to avoid any accidents or tears with the airline tubing.
终点
Aryan Haghighi
于01/11/21注册
121 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 148
