跳转到主内容
Aquaris M5 Loud Speaker Replacement
你所需要的
  1. Aquaris M5 Loud Speaker Replacement, Back Cover: 步骤 1 中的图像 1,2 Aquaris M5 Loud Speaker Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Insert the tip of an iFixit opening tool between the back cover and the mid frame of the phone.
    • Between the 2 SIM card slots is a good place to start.
    • Slide the opening tool to the bottom of the phone, to snap out the plastic clips, connecting the back cover and mid frame.
  2. Aquaris M5 Loud Speaker Replacement: 步骤 2 中的图像 1,2 Aquaris M5 Loud Speaker Replacement: 步骤 2 中的图像 2,2
    • Slide the opening tool back to the top of the phone, to disconnect all the clips on the edge.
    • Slide around the corner and along the top edge, to also disconnect these clips.
  3. Aquaris M5 Loud Speaker Replacement: 步骤 3 中的图像 1,3 Aquaris M5 Loud Speaker Replacement: 步骤 3 中的图像 2,3 Aquaris M5 Loud Speaker Replacement: 步骤 3 中的图像 3,3
    • Be careful not to bend the back cover too hard to prevent some of the clips breaking.
    • Grab the back cover by the loosened edge.
    • Gently bend and twist the flexible back cover a bit to disconnect the remaining clips.
    • Take off the back cover.
  4. Aquaris M5 Loud Speaker Replacement, Battery: 步骤 4 中的图像 1,1
    • Damaging the liquid indicator sticker, on the middle most screw, will void the warranty of the phone.
    • Unscrew the ten black 4mm Phillips #00 Screws from the mainboard shield.
    • Unscrew the golden 3.4mm Phillips #00 screw on the middle-right side of the mainboard shield.
  5. Aquaris M5 Loud Speaker Replacement: 步骤 5 中的图像 1,3 Aquaris M5 Loud Speaker Replacement: 步骤 5 中的图像 2,3 Aquaris M5 Loud Speaker Replacement: 步骤 5 中的图像 3,3
    • Insert the flat side of a spudger between the mainboard shield and the frame of the phone.
    • Twist the spudger to lift up the mainboard shield.
    • Remove the mainboard shield from the phone.
  6. Aquaris M5 Loud Speaker Replacement: 步骤 6 中的图像 1,2 Aquaris M5 Loud Speaker Replacement: 步骤 6 中的图像 2,2
    • Use a spudger to disconnect the battery's flex cable from the mainboard.
    • Pull of the sticker on the bottom side of the battery.
    • Grab the sticker and lift it up to take the battery out of the phone.
  7. Aquaris M5 Loud Speaker Replacement, Loud Speaker: 步骤 7 中的图像 1,1
    • Take out the seven 4mm Phillips #00 screws, holding the loud speaker unit to the mid frame of the phone.
  8. Aquaris M5 Loud Speaker Replacement: 步骤 8 中的图像 1,2 Aquaris M5 Loud Speaker Replacement: 步骤 8 中的图像 2,2
    • Insert the flat side of a spudger into the gap on the right side of the loud speaker.
    • Lever the loud speaker up with the spudger.
    • Grab the loud speaker and take it out of the phone.
结论
另外一个人完成了本指南。
Theo Mat
于11/12/17注册
12,782 声望
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 449
