简介
Use this guide to replace the daughterboard of your bq Aquaris M5.
你所需要的
Insert the tip of an iFixit opening tool between the back cover and the mid frame of the phone.
Slide the opening tool to the bottom of the phone, to snap out the plastic clips, connecting the back cover and mid frame.
Unscrew the ten black 4mm Phillips #00 Screws from the mainboard shield.
Unscrew the golden 3.4mm Phillips #00 screw on the middle-right side of the mainboard shield.
Take out the seven 4mm Phillips #00 screws, holding the loud speaker unit to the mid frame of the phone.
Use tweezers to disconnect the antenna cable from the daughterboard.
Unscrew the black Phillips #00 screw, that holds the power and volume buttons in place.
Use the flat end of a spudger to disconnect the flex cable from the mainboard.
另外一个人完成了本指南。
