跳转到主内容
Apple iSight Webcam Privacy Lens Replacement
你所需要的
  1. Apple iSight Webcam Privacy Lens Replacement, External Body Frame: 步骤 1 中的图像 1,1
    • Remove two 3.55 mm screws that hold the body to the ball and socket joint using the PH000 screwhead.
  2. Apple iSight Webcam Privacy Lens Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Insert the tweezers into the crevice of the ball and socket joint, and prop up the tabs to remove the white ring from the body.
  3. Apple iSight Webcam Privacy Lens Replacement: 步骤 3 中的图像 1,2 Apple iSight Webcam Privacy Lens Replacement: 步骤 3 中的图像 2,2
    • Press the Apple logo through to pull apart the body frame from the body of the webcam.
  4. Apple iSight Webcam Privacy Lens Replacement, Privacy Lens: 步骤 4 中的图像 1,1
    • Remove the end cap with the Apple logo by simply pulling it off.
  5. Apple iSight Webcam Privacy Lens Replacement: 步骤 5 中的图像 1,2 Apple iSight Webcam Privacy Lens Replacement: 步骤 5 中的图像 2,2
    • Unscrew the 3 (3.55 mm) screws surrounding the black casing near the camera-lens.
  6. Apple iSight Webcam Privacy Lens Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using tweezers, remove the netting that surrounds the black casing.
  7. Apple iSight Webcam Privacy Lens Replacement: 步骤 7 中的图像 1,1
    • Pry open the top of the black casing and pull it off.
    • There is slot on each side just below the power cord connector.
  8. Apple iSight Webcam Privacy Lens Replacement: 步骤 8 中的图像 1,1
    • Unscrew 2 (4.41 mm) screws seen in the picture that surround the attachment of the lens to the main body.
  9. Apple iSight Webcam Privacy Lens Replacement: 步骤 9 中的图像 1,2 Apple iSight Webcam Privacy Lens Replacement: 步骤 9 中的图像 2,2
    • ,Pull the loose circuit strip from its connection using tweezers.
    • Do this for the side connection as well. This enables the entire camera lens section to come off.
    • Pull the camera lens section off the main body.
  10. Apple iSight Webcam Privacy Lens Replacement: 步骤 10 中的图像 1,2 Apple iSight Webcam Privacy Lens Replacement: 步骤 10 中的图像 2,2
    • Unscrew the final (4.41 mm) screw that connects the lens circuitry to the aperture.
    • Then pull off the circuitry top section.
  11. Apple iSight Webcam Privacy Lens Replacement: 步骤 11 中的图像 1,2 Apple iSight Webcam Privacy Lens Replacement: 步骤 11 中的图像 2,2
    • Pull off the top piece of the lens aperture.
    • Finally, remove the privacy lens using tweezers.
结论
4等其他人完成本指南。
Cullen Shorey
于03/21/18注册
271 声望
撰写一个指南
团队
IUPUI, Team S5-G1, Baechle Spring 2018 IUPUI, Team S5-G1, Baechle Spring 2018 的会员
IUPUI-BAECHLE-S18S5G1
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 22
总计 1,183
