跳转到主内容
Apple iSight Webcam Camera Replacement
你所需要的
  1. Apple iSight Webcam Camera Replacement, External Body Frame: 步骤 1 中的图像 1,1
    • Remove two 3.55 mm screws that hold the body to the ball and socket joint using the PH000 screwhead.
  2. Apple iSight Webcam Camera Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Insert the tweezers into the crevice of the ball and socket joint, and prop up the tabs to remove the white ring from the body.
  3. Apple iSight Webcam Camera Replacement: 步骤 3 中的图像 1,2 Apple iSight Webcam Camera Replacement: 步骤 3 中的图像 2,2
    • Press the Apple logo through to pull apart the body frame from the body of the webcam.
  4. Apple iSight Webcam Camera Replacement, Camera: 步骤 4 中的图像 1,1
    • Remove the end cap with the Apple logo by simply pulling it off.
  5. Apple iSight Webcam Camera Replacement: 步骤 5 中的图像 1,2 Apple iSight Webcam Camera Replacement: 步骤 5 中的图像 2,2
    • Unscrew the 3 (3.55 mm) screws surrounding the black casing near the camera-lens.
  6. Apple iSight Webcam Camera Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using tweezers, remove the netting that surrounds the black casing.
  7. Apple iSight Webcam Camera Replacement: 步骤 7 中的图像 1,1
    • Pry open the top of the black casing and pull it off.
    • There is slot on each side just below the power cord connector.
  8. Apple iSight Webcam Camera Replacement: 步骤 8 中的图像 1,2 Apple iSight Webcam Camera Replacement: 步骤 8 中的图像 2,2
    • Gently pull out the ribbon cables at the base of the circuit board. The camera module and lens cap are connected to the board via two busses.
    • Make sure that all pins are loose before pulling them out or you could risk bending the pins or breaking the connector.
  9. Apple iSight Webcam Camera Replacement: 步骤 9 中的图像 1,2 Apple iSight Webcam Camera Replacement: 步骤 9 中的图像 2,2
    • Remove the three PH000 3.55mm screws that connect the end cap that holds the privacy shutter to the rest of the camera enclosure. Once the screw are removed, you can pull them apart.
  10. Apple iSight Webcam Camera Replacement: 步骤 10 中的图像 1,2 Apple iSight Webcam Camera Replacement: 步骤 10 中的图像 2,2
    • Unscrew the three PH000 3.55mm screws from the connecting plate and the camera enclosure. Pull apart when all screws are removed.
  11. Apple iSight Webcam Camera Replacement: 步骤 11 中的图像 1,1
    • Unscrew the three PH000 3.55mm screws securing the Camera module circuit board and lens enclosure.
  12. Apple iSight Webcam Camera Replacement: 步骤 12 中的图像 1,1
    • Pull the pin tab from the base of the circuit board to separate the camera module and the lens enclosure.
结论
3等其他人完成本指南。
Kaleb McArdle
于03/21/18注册
175 声望
撰写一个指南
团队
IUPUI, Team S5-G1, Baechle Spring 2018 IUPUI, Team S5-G1, Baechle Spring 2018 的会员
IUPUI-BAECHLE-S18S5G1
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 41
总计 2,746
