跳转到主内容
Apple iPod Hi-Fi Grille Replacement
你所需要的
  1. Apple iPod Hi-Fi Grille Replacement, Grille: 步骤 1 中的图像 1,1
    • Warm up the glue by using the hair dryer on the grille for 5-10 minutes.
    • You can skip this step if you don't have access to a hair dryer. However, if you skip this step, the next step will take longer and will be harder.
  2. Apple iPod Hi-Fi Grille Replacement: 步骤 2 中的图像 1,1
    • Take one spudger and fit it under the grille.
    • Use your first spudger to pry up and make room to insert a second one.
    • Sever the glue connections between the grille and the device by moving one spudger around, cutting through the glue.
    • Use the other spudger to raise the grille, allowing you to see where you're working.
    • Since you're cutting the glue, the grille may not stick as well when reassembled.
  3. Apple iPod Hi-Fi Grille Replacement: 步骤 3 中的图像 1,1
    • Pull the grille off the Apple iPod Hi-Fi with your hands.
结论
5等其他人完成本指南。
团队
Cal Poly, Team S16-G1, Livingston Spring 2018 Cal Poly, Team S16-G1, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S16G1
5 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 21
总计 1,415
