跳转到主内容
Apple iPod Hi-Fi Front Panel and Speaker Connections Replacement
你所需要的
  1. Apple iPod Hi-Fi Front Panel and Speaker Connections Replacement, Grille: 步骤 1 中的图像 1,1
    • Warm up the glue by using the hair dryer on the grille for 5-10 minutes.
    • You can skip this step if you don't have access to a hair dryer. However, if you skip this step, the next step will take longer and will be harder.
  2. Apple iPod Hi-Fi Front Panel and Speaker Connections Replacement: 步骤 2 中的图像 1,1
    • Take one spudger and fit it under the grille.
    • Use your first spudger to pry up and make room to insert a second one.
    • Sever the glue connections between the grille and the device by moving one spudger around, cutting through the glue.
    • Use the other spudger to raise the grille, allowing you to see where you're working.
    • Since you're cutting the glue, the grille may not stick as well when reassembled.
    Antes de poner de vuelta la placa de aluminio con el mismo secador de aire caliente puedes calentar los restos de pegamento adherido y lo montas . Pones la rejilla de tela en su lugar y lo dejas una hora apoyado con la parte trasera mirando hacia arriba.asi el pegamento recalentado y con la presión del peso del aparato hará que se adhiera.
    Olga Ona - 回复
  3. Apple iPod Hi-Fi Front Panel and Speaker Connections Replacement: 步骤 3 中的图像 1,1
    • Pull the grille off the Apple iPod Hi-Fi with your hands.
  4. Apple iPod Hi-Fi Front Panel and Speaker Connections Replacement, Front Panel and Speaker Connections: 步骤 4 中的图像 1,2 Apple iPod Hi-Fi Front Panel and Speaker Connections Replacement, Front Panel and Speaker Connections: 步骤 4 中的图像 2,2
    • Remove all eight 3.3mm JIS #1 screws holding the front panel in place by placing the screwdriver in the head of the screw and rotating counterclockwise.
    • Remove the four 3.3mm JIS #1 screws holding the large speaker in place by placing the screwdriver in the head of the screw and rotating counterclockwise.
  5. Apple iPod Hi-Fi Front Panel and Speaker Connections Replacement: 步骤 5 中的图像 1,2 Apple iPod Hi-Fi Front Panel and Speaker Connections Replacement: 步骤 5 中的图像 2,2
    • Pry out the large speaker with a metal spudger around the edge.
    • Remove the speaker slowly from its socket with your hands.
    • Turning the speaker on its side will make this step much easier.
    • The speaker is still attached by several connections at this point so the speaker will not be able to be removed completely at this step.
  6. Apple iPod Hi-Fi Front Panel and Speaker Connections Replacement: 步骤 6 中的图像 1,2 Apple iPod Hi-Fi Front Panel and Speaker Connections Replacement: 步骤 6 中的图像 2,2
    • Press down on the tab and pull out with your hands to remove the cable connecting the large speaker from the rest of the unit.
    • Pull the large speaker completely out and set aside.
  7. Apple iPod Hi-Fi Front Panel and Speaker Connections Replacement: 步骤 7 中的图像 1,1
    • Remove the sensor connection by pulling it straight out with your hand.
  8. Apple iPod Hi-Fi Front Panel and Speaker Connections Replacement: 步骤 8 中的图像 1,3 Apple iPod Hi-Fi Front Panel and Speaker Connections Replacement: 步骤 8 中的图像 2,3 Apple iPod Hi-Fi Front Panel and Speaker Connections Replacement: 步骤 8 中的图像 3,3
    • Pull the entire front assembly off by prying it up with the spudger and lifting the assembly off with your hands towards the top of the Hi-Fi.
    • There are still connections attached at this stage so the front assembly will not completely disconnect from the rest of the device .
  9. Apple iPod Hi-Fi Front Panel and Speaker Connections Replacement: 步骤 9 中的图像 1,2 Apple iPod Hi-Fi Front Panel and Speaker Connections Replacement: 步骤 9 中的图像 2,2
    • Remove the clips for the remaining two speakers by repeating step 6.
    • Remove the last connection that connects the speakers to the power box.
    • Remove the front panel completely.
    • When reassembling, the ports are labeled "right" and "left" to help you plug in the right speaker to the right port.
结论
7等其他人完成本指南。
团队
Cal Poly, Team S16-G1, Livingston Spring 2018 Cal Poly, Team S16-G1, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S16G1
5 名成员
创作了16篇指南
4条评论
Hi, I would like to know where to purchase replacement speakers for the Apple HiFi. TIA
Michael Philip V. Regino - 回复
Hi whehe can i find a replacement bass speaker ??
Juan Carlos Destombes - 回复
Yo necesito la fuente de poder de ese equipo, por favor si alguien lo tiene me escribe a: rolando.chungag@gmail.com
rolando.chungag - 回复
Nesesito el diagrama electrico del controlador de volumen por que le entro un raton a mi vocina & se comio los cables alguien q me pueda pasar el dato por favor
cgok_666 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 84
总计 4,038
