跳转到主内容
Apple Wireless Keyboard Logic Board Replacement
你所需要的
  1. Apple Wireless Keyboard Logic Board Replacement, Logic Board: 步骤 1 中的图像 1,2 Apple Wireless Keyboard Logic Board Replacement, Logic Board: 步骤 1 中的图像 2,2
    • Insert a metal spudger to open the plastic part under the Keyboard
  2. Apple Wireless Keyboard Logic Board Replacement: 步骤 2 中的图像 1,1
    • Remove the screw
  3. Apple Wireless Keyboard Logic Board Replacement: 步骤 3 中的图像 1,3 Apple Wireless Keyboard Logic Board Replacement: 步骤 3 中的图像 2,3 Apple Wireless Keyboard Logic Board Replacement: 步骤 3 中的图像 3,3
    • Pull the lock up and disconnect the connection cable
  4. Apple Wireless Keyboard Logic Board Replacement: 步骤 4 中的图像 1,1
    • Keeping the connection cable, push out the logic board's placement
    On some recent version of the keyboard, there's a plastic pin under the white logic board plastic holder, keeping the whole thing in position in the aluminium tube.
    You may have to pull slightly upward while pushing the logic board out of the tube to disengage the plastic pin.
    Kuf - 回复
  5. Apple Wireless Keyboard Logic Board Replacement: 步骤 5 中的图像 1,1
    • Unlock the latch of the logic board
  6. Apple Wireless Keyboard Logic Board Replacement: 步骤 6 中的图像 1,1
    • Remove the logic board from the placement
结论
20等其他人完成本指南。
Nicola
于11/14/13注册
638 声望
撰写一个指南
9条评论
Hi, anyone know where its possible to buy this logic board? My bluetooth chip is apparently broken
steve - 回复
Which model of keyboard is this, because my A1255 doesn't disassemble like this - the battery terminal is solidly restrained inside the tube by means of a metal expansion ring. Doesn't seem user repairable :(
gordon jackson - 回复
My power button was stuck. The shell was dented. This was an easier way to access and remove the button so I was able to file the inside of the tube smooth so the button would move freely.
Tony - 回复
I have disassembled my keyboard as shown above, but now I need a replacement Wireless Keyboard Logic Board. I have not been able to find one. Any suggestions?
Martin Rubio - 回复
Very nice! in my case the flat cable was not properly connecting. I only found out when i opened the cap to the logic board and saw the cable sitting slanted in its connector. Put it back straight and now it works again. Cheers!!
mollymol - 回复
Great, now my Keyboard work thanks a lot!!!!!!!!
Maurizio - 回复
My keyboard empties a fully loaded set of batteries in 1 day, anybody had an idea wat it could be?
Wesley Looy - 回复
I bought used keyboard. It empties a set of batteries in less then a day. Plus it looses connections. Any ideas what this is?
koncan - 回复
Hello! My keyboard has some keys that stopped working: delete, return, r-shift, caps lock, r-option, tab. The rest of the keys work fine. Any suggestions?
Mariano Belgrano - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 35
过去 30 天: 121
总计 49,208
