快速对比 Series 5 和去年的版本后,区别很小。我们需要用撬棒来挖掘出更多的不同之处。开始之前,以下是我们已知的参数:
具备力度触控功能的 LTPO OLED 全天候视网膜显示屏
Apple 定制的 64 位 双核 S5 SiP(系统级封装)
光学心率传感器及电极式心率传感器
仅 GPS 或可配备 LTE,配备指南针和高度计
50 m 防水
断开电源前需要拆除用粘合剂固定的电池,我们知道该怎么做(尽管我们保留操作时炸毛的权利)。
今年的电源标记着 A2181 并提供 1.129 Wh 能量(296 mAh @ 3.814 V)。
数值上对比去年的 1.113 Wh 电池有了非常轻微的 1.44% 的提升。显然电池的提升不能带来全天候显示下 18 小时的续航,这个技术应该时别的东西带来的。
What is the tape on the flex cables with the connections at each end?
were do l buy this part
由衷感谢以下译者:
100%
Patrick Zhang正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
13条评论
How to replace watch crown
I’m not sure if the crown can be replaced after all. I tried to get it off on the Series 4 without success (the stem broke). Apple Watch Series 4 拆解
What can I do if the backside has scars?
I’m pretty sure you can replace the whole back housing (glass + heart rate sensor assembly, which u can find on ali)
Savez vous si le bouton fonctionne si un composant de l’écran est abîmé ?
en changeant l’écran sans vérifier avant si le bouton Digital Crown fonctionnait.
Le bouton Digital Crown est relativement indépendant du reste. Il ne peut pas être retirée, donc normalement, il devrait toujours fonctionner et ne pas être affecté par le remplacement de l’écran ou de la batterie.
Is there anyway to separate the heartbeat monitor from the back housing while only allowing damage to the frame?
We couldn’t manage to separate those two parts.
I understand that the flex Cable has two screws on either side, one Is the force touch and the other I’m not sure, can you tell me?
Accidentally ripped the cable in the bottom right edge of the watch (next to the display connectors) on the inside of the Watch, was that the force touch gasket?
How to replace the side button?
Is it possible to replace the speaker mine is damaged and I would like some help or at least a walk through on how it is done this watch was a gift and It means a lot if someone could help me repair it especially for the speaker series 5 44mm cellular
Hi, what is name of flex cables? I'm talking about the cable that is glued to the flex cables leading to the display, I accidentally tore it off and I can't find the name anywhere.
