跳转到主内容
Apple Watch Series 3 屏幕更换
你所需要的
  1. Apple Watch Series 3 屏幕更换, 打开显示屏: 步骤 1 中的图像 1,1
    • 准备iOpener,并加热显示屏以软化粘合剂,将其固定到位。
    I have heated up the iOpener to 165 degrees and left it on for more than a minute. No way I can lift the screen off with the exact knife. Tried different angles in various places, but no go. I also used a hair dryer un til the watch screen was too hot to touch and even tried a very hard cutting tool blade and also no go. Could n ever get the blade under the face I applied enough force where I could see that the blade left small marks, not very big, but could never get anything to move or lift. What am I doing wrong? I spent 47 years at a global computer company and I am used to taking apart small things and applying force when required. I don’t know what I am doing wrong. Please help me.
    Rafael Blanco - 回复
    Getting the initial gap is not easy. Maybe a playing card could work its way in the tiny gap and cut some adhesive. After that there might be some success with an exacto knife. Or you want to try a piece of aluminum foil (folded for more rigidity) for cutting the adhesive. Be aware of the force touch gasket and that it might get damaged during that procedure.
    Tobias Isakeit -
    I finally used a hot air gun set to 150 deg. C heating up the edges by slowly spinning the watch around before the technique worked. Difficult is the level noted and it’s correct. Finally worked and watch perfectly functioning.
    Chris Giavotto - 回复
    I used a heat gun, too. I was worried after reading comments that it would burn up the LCD, so I heated it a little bit at a time, rotating it like you did, and checking to see if I could get my knife under it. I must have hit one of the buttons because it did turn on, but that did reassure me that the display was okay.
    It's open. Now that the watch and I have had a few minutes to cool down, I'm ready for the next step. Not as difficult as I thought it could be. Tomorrow, I'll be replacing the battery in an iPod Touch 6th Gen.
    bester -
    I had to heat the iOpener 2 times and leave it on top of the watch for 10 minutes.
    Axel Trujillo - 回复
  2. Apple Watch Series 3 屏幕更换: 步骤 2 中的图像 1,3 Apple Watch Series 3 屏幕更换: 步骤 2 中的图像 2,3 Apple Watch Series 3 屏幕更换: 步骤 2 中的图像 3,3
    • 始终保持手指完全远离刀。 千万不要施加太大的压力,因为这可能会导致刀滑动并切割或损坏手表。
    • 仅将刀片的细边插入间隙,然后朝您的方向倾斜刀片以加宽间隙,并将显示屏略微抬起。
    • 将弯曲刀片的边缘放入显示器和外壳之间的薄间隙中。 从显示屏的短边开始,最靠近圆形圈。
    • 不要将刀插入1/16英寸(约2毫米)。
    It’s difficult to grip case in a way that keeps fingers safe from the blade but doesn’t hit the side buttons and turn the device on!
    If it’s a struggle to get the display to release, warm case for a few more minutes.
    Kyle Powderly - 回复
    I have tried so may times to get the display to release but nothing works. Should have bought a new watch LOL. Kept the iOpener on 2 times for 10 minutes and it still won't open. There must be a better way.
    Susan E. White - 回复
    Hi Susan,
    if you're struggling to get the adhesive loose enough a hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device. The edge should feel slightly too hot to the touch.
    Dominik Schnabelrauch -
  3. Apple Watch Series 3 屏幕更换: 步骤 3 中的图像 1,2 Apple Watch Series 3 屏幕更换: 步骤 3 中的图像 2,2
    • 一旦使用刀片打开了小间隙,请移除刀片并将打开工具的较薄边缘插入间隙中。
    • 在此插入翻译将开口工具推入间隙,用拇指作为支点,将显示屏再打开一点。
    • 现在不要试图完全分离显示屏。 Force Touch垫圈可能会粘在显示器或机身上,如果用力过猛,可能会被撕裂。
  4. Apple Watch Series 3 屏幕更换: 步骤 4 中的图像 1,3 Apple Watch Series 3 屏幕更换: 步骤 4 中的图像 2,3 Apple Watch Series 3 屏幕更换: 步骤 4 中的图像 3,3
    • 在显示屏下方插入一个开口拨片,小心地将Force Touch垫圈与显示屏分开。
    • 确保您找对了位置。 如果在抬起显示屏时把Force Touch垫片分离了,或者您将垫圈层分开,则还需要更换Force Touch垫圈本身。
    • 在显示屏周围滑动拨片以分离Force Touch垫圈和显示屏之间的粘合剂。
    • 不要将开口拨片插入深度超过1/16英寸(~2 mm)。
  5. Apple Watch Series 3 屏幕更换: 步骤 5 中的图像 1,3 Apple Watch Series 3 屏幕更换: 步骤 5 中的图像 2,3 Apple Watch Series 3 屏幕更换: 步骤 5 中的图像 3,3
    • 为避免损坏显示屏电缆,请勿完全打开显示屏。
    • 将显示屏打开约45°角,然后用镊子剥去显示屏和Force Touch垫圈之间的粘合剂。
    • 将粘合剂穿过显示器电缆的周围和后面,使其完全脱落,然后向下按压垫圈以重新粘附到盒子上。
    • 如果Force Touch垫圈本身松动且不会向下弯曲,则应更换垫圈下方和垫圈与显示屏之间的粘合剂。
  6. Apple Watch Series 3 屏幕更换, 断开电池连接: 步骤 6 中的图像 1,3 Apple Watch Series 3 屏幕更换, 断开电池连接: 步骤 6 中的图像 2,3 Apple Watch Series 3 屏幕更换, 断开电池连接: 步骤 6 中的图像 3,3
    • 卸下固定金属盖板的Y型#000螺丝。
    • 用一把镊子取下盖板。
    • 首先打开盖板。
    • 然后将其关闭一半,将其完全取出。
    Pictures are the GPS version. Cellular doesn’t have the gap and separate removable plate on the “taptic engine” section.
    Ryan Holt - 回复
    What if I’m unable to unscrew the screw? I’m using the right tool, but it just won’t do it. It feels like it can’t “lock in” if you know what I mean in order to be able to get enough grip to turn the screw. Any suggestions?
    Cade Capper - 回复
    Once you have the driver set properly in the screw you have to lean into it to get it to turn. The screw is coated with LockTight.
    mailghall - 回复
  7. Apple Watch Series 3 屏幕更换: 步骤 7 中的图像 1,3 Apple Watch Series 3 屏幕更换: 步骤 7 中的图像 2,3 Apple Watch Series 3 屏幕更换: 步骤 7 中的图像 3,3
    • 在仅有GPS的版本上,可以在卸下金属板后立即断开电池。 对于LTE版本,你首先需要断开Force Touch垫圈并将其折叠,以便断开电池连接。
    • 使用撬棒的尖端直接向上撬起连接器来断开电池连接。
    • 稍微弯曲连接器,确保它不会意外接触到主板。
    whats does it happen if the connector make contact by accident????
    Daniel Sanchez - 回复
  8. Apple Watch Series 3 屏幕更换, 屏幕: 步骤 8 中的图像 1,2 Apple Watch Series 3 屏幕更换, 屏幕: 步骤 8 中的图像 2,2
    • 用一把镊子剥掉覆盖显示屏电缆连接器的胶带。
    • 从磁带的右下角开始,小心地朝中间的接口方向前进。
    • 这个胶带可能会很粘,所以请小心不要拉得太用力导致底下的电缆被损坏。如果需要的话,可以加一点热或者使用一些异丙醇来使胶带软化
    Das Klebeband muss gar nicht vollständig abgelöst werden. Es reicht aus, die Stecker freizulegen. So hat man beim Wiederzusammensetzen das Klebeband wieder in der optimalen Position und auch nicht das Risiko, die leitende Folie zu verletzen.
    BMJ - 回复
    BMJ's comment translated by translate dot google dot com:
    "The adhesive tape does not need to be completely removed. It is enough to expose the connectors. This means that when you put it back together you have the adhesive tape in the optimal position again and there is no risk of damaging the conductive film."
    Robert - 回复
  9. Apple Watch Series 3 屏幕更换: 步骤 9 中的图像 1,3 Apple Watch Series 3 屏幕更换: 步骤 9 中的图像 2,3 Apple Watch Series 3 屏幕更换: 步骤 9 中的图像 3,3
    • 在最左边的接口上是一块导电箔,在取下胶带时可能会撕裂。
    • 如果它撕裂,从左下方抓住它以完全移除它。这样的话,底下对应的一个导电箔(显示器上的)将不会被损毁。
    How important is the conductive tape?
    John Ellis - 回复
  10. Apple Watch Series 3 屏幕更换: 步骤 10 中的图像 1,3 Apple Watch Series 3 屏幕更换: 步骤 10 中的图像 2,3 Apple Watch Series 3 屏幕更换: 步骤 10 中的图像 3,3
    • 小心地使用撬挖工具或者一个干净的指甲通过撬开电缆正对着的接口上的三个小黑翻板锁来打开三个ZIF连接器上的第一个。
    Ir is viral to lift the small black flap or you ruin the entire process here, I lost everythign here...the first one stuck and the entire connector discintigrated on me, not my first rodeo, but lost the entire project.
    Lisa Russell - 回复
  11. Apple Watch Series 3 屏幕更换: 步骤 11 中的图像 1,3 Apple Watch Series 3 屏幕更换: 步骤 11 中的图像 2,3 Apple Watch Series 3 屏幕更换: 步骤 11 中的图像 3,3
    • 在剩下的两个连接器上撬开翻板锁
    • 替换的屏幕是要安装在关上的翻板锁上的。所以在重新组装的时候,插入电缆之前,确保翻板锁是开的,否则你将损坏你的手表。
  12. Apple Watch Series 3 屏幕更换: 步骤 12 中的图像 1,3 Apple Watch Series 3 屏幕更换: 步骤 12 中的图像 2,3 Apple Watch Series 3 屏幕更换: 步骤 12 中的图像 3,3
    • 使用一把镊子轻轻拉出显示器的柔性电缆来断开它们。
    • 如果电缆卡住了,在拉它们出来时尝试小心地左右摇动电缆。
  13. Apple Watch Series 3 屏幕更换: 步骤 13 中的图像 1,1
    • 取下显示屏。
    • 详细的重新组装指南,包括更换Force Touch垫圈和周边粘合剂,请参照本指南
    hi
    how are you
    Please answer me quickly
    i have a apple watch 3 and broken lcd
    can i replace this lcd with a lost apple watch lcd?
    Does it work?
    I've heard that Apple does not allow this and ban the device!!!!
    Hossean Dad - 回复
结论
从第十步开始按照我们的 Apple Watch Series 3 Force Touch 垫圈更换教程 来重新密封你的Apple Watch并完成整个维修。 注意,为了最佳结果,不要在第16步之前将你的新显示屏连接上。
299等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Tobias Isakeit
于03/31/14注册
117,588 声望
创作了188篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,528篇指南
52条评论
“Replacing the display can cause issues with Apple Pay.“
If ApplePay could possibly be disabled by this procedure, then seems like a show stopper.
Is ApplePay still an issue?
Joel Weston - 回复
This is indeed something we can not rule out entirely. There are too many options to consider and we are not able to test all of them (type of replacement screen, software related issues with WatchOS and paired/unpaired watches. The NFC chip is the main issue here since it lives on the display and is responsible for Apple Pay. We are happy for any insight others can provide to offer a working solution/guide.
Tobias Isakeit -
I will try this once i get a display from iFixit. Thanks :) i hope it works
Kundan Agrawal - 回复
Apne display kaha se or kitne ka kharida , pls tel me
Honey Gothwal -
Hey guys, I replaced the screen and once I turned it on I got the green snake screen. When I try to charge it, it gets really hot now. Did I damage the battery or anything else?
Aaron - 回复
Hi Aaron,
assuming all cables and components are fine and not damaged (check for creases, kinks or rips as well as making sure all connectors sit tight) you might want to try these steps and see if the watch boots up properly:
1. use a working charging cable/unit and power adapter (maybe borrow one from a friend)
2. wait at least one hour to see if the watch boots up.
3. try to force restart the watch (push and hold the side button and the crown until the Apple logo appears) and then charge it.
4. let the battery run down until the watch shuts off on its on and leave it off for another day for the battery to deplete completely. Then try charging it.
Tobias Isakeit -
Hi Aaron,
The green snake of death is ok - that just means the battery is charging, and doesn't have enough to turn on yet. The red snake of death however is bad, meaning that the either charger or charge port is faulty.
I could be wrong, the information I was told was quite, odd...
Referenced Site - Apple - Green Snake and Green Snake Info
Nate Campbell -
Hello.
An acquaintance bought a Series 3 42mm replacement screen and I set out to make the swap for him using this guide. There is a metal loop above one of the ribbon connectors on the back of the screen near the edge. This loop is not in the same place as it was on the original screen, and as such does not contact the small brass clip on the watch frame like it’s supposed to.
Upon closer inspection, it seems he ordered a Cellular screen and has a GPS watch. Would that account for this difference? It is the only difference between the two screens that I can see with the naked eye.
Thanks,
Stephen Butterfield - 回复
Hello, yes, the cellular and the Gps version screens are different, it would not fit
wxllxmarketing -
Hey guys
I have forget to delete the Credit Card before i replace the Display and now i have an error message when i configurate Apple Pay. How can i fix it ?
Andreas Haack - 回复
Hi Andreas, you may either re-install the old display (if it’s working to that degree as to remove the credit card settings) and then perform the repair again. Or you may reset your watch (provided you have a recent backup) and set it up from that backup. (No guaranty this will work)
Tobias Isakeit -
Hello did this work for you?
James -
After doing this fix/replacement of a cracked screen, should I assume the watch is no longer water resistant and avoid wearing it in pool, shower, hot tub, etc?
Robert Sarvis - 回复
That’s correct. A manually fixed and closed watch display might not be as tight as a manufactured Apple Watch. I would refrain from submerging it in water to be on the safe side.
Tobias Isakeit -
Is it possible to just replace the glass? my screen displays perfectly the glass is just cracked in away that I can’t enter my passcode.
Michael Ryan - 回复
Hi Michael, though it is possible to only change the glass, I’d not recommend it. You might feel the same after watching this video (it’s a Series 4 but basically the same procedure for the glass)—or you feel empowered by it and will try that procedure (with success hopefully): https://www.youtube.com/watch?v=PZYWzsB_...
Tobias Isakeit -
My Apple Watch screen is very broken and has lifted slightly. Is it still possible to repair it?
Dianne Waszak - 回复
Hi Dianne, if the watch didn’t suffer from any water that might have gotten in, you’ll be definitely able to repair it with a new display. Just be careful with the glass shards. And if you use Apple Pay, make sure you delete any credit card information before removing the old screen to avoid any problems with the NFC chip on the new display (see introduction).
Tobias Isakeit -
Hi, where can i buy the screen for apple watch series 3?
Searched online, only whole unit is available and it’s quite expensive. So, i was wondering if i can purchase the screen only.
Rasul Rukhillaev - 回复
Hi Rasul, here you can find the different Series 3 screens: [[ 无效部分链接 ]]
If you only want to change the glass you probably want to search for the procedure online if you’re up to the challenge ;)
Tobias Isakeit -
So I did this fix a while back (for my wife’s watch), and everything seemed to go well. But a week later, the adhesive failed and the face ended up popping off. I reheated and stuck it back on, but a few weeks later it again popped off. The watch is basically unusable for my wife, all bc the adhesive isn’t sticking. What now? Expensive repair to be thwarted by weak adhesive.
Robert Sarvis - 回复
@isakrittl any comments/suggestions
should I just buy some regular glue (what kind) to make it stick better?
Robert Sarvis -
Hi Robert, congrats on the repair so far. Assuming you cleaned every little bit of remaining adhesive from the frame and the display and the new adhesive still won’t hold, you might want to try the E6000 glue. It’s an industrial glue and needs to be applied very carefully to not get on unwanted areas. I wish you a successful repair
Tobias Isakeit -
@isakrittl
You guys should either include better adhesive or tell ppl to buy their own right off the bat. As noted above already, the weak adhesive led to her screen popping off multiple times. The repeated popping off apparently led to one of the minuscule clips holding the electrical ribbons from the watch to the screen breaking, so the screen doesn’t work and is now useless. So I'm out $170 bucks bc of the crappy cheap-o adhesive strip they provide (or possibly the clip was weak to begin with--only one of them broke). If I buy a new screen, I'll have spent more than the price of a new and better Apple Watch. FML. Apparently redditors are aware the adhesive strips suck and just buy separate adhesive. Why would iFixit not provide legit adhesive? It's $170 on the line! EXTREMELY DISAPPOINTED!!!
Robert Sarvis -
hi, I broke my apple watch and I was wondering if you can use another series glass to fix an apple watch series 3?
If not is there cheaper ways to fix your apple watch?
Aria Nanayakkara - 回复
as of today April 2020, you can buy the new screen for 200 bucks or buy a new S3 watch for 199.00. Why would I invest 200 into a used watch when I can buy a new one for 199?
Art - 回复
Hi, I’m unsure of what parts to buy to replace my screen. I dropped my watch and the screen is fully cracked. The buttons still work but the touchscreen does not. Would it just be a new screen or the digitiser too?
Joana ॐ - 回复
Dag, Ik lees dat bij het vervange van het scherm apple pay soms niet meer werkt.
Dat is bij mij dus het geval. Heeft u ook een oplossing om apple pay weer aan de gang te krijgen?
Mvg Folkert
Folkert - 回复
Where is the guide for installing the new screen? I don’t see that anywhere….
Jerrod Eshleman - 回复
See link in the conclusion box: Continue from Step 10 of our Force Touch Sensor guide to re-seal your watch and complete your repair.
Tobias Isakeit -
Also I was able to preserve the force touch gasket, so does that mean I don’t need to install the one that came with the kit? If so, then how does the screen adhere to the watch?
Will the Apple Watch (38 mm Series 3 Cellular) Screen work fine on the GPS version?
Ryan Simpson - 回复
I have the same question
Amy Halfacre -
replace the screen but the new screen wont light up it turns on
josh - 回复
I feel like this is $@$*!&. I tried everything and it still don’t work. I want a refund.
Savannah Tacy - 回复
I have a series 3 GPS, (non cellular, at least, I assume its gps then). crystal is cracked and I can’t enter the PIN because of it. i wanted to just buy a new series 3 apple watch but the new ones won’t work with an Iphone 6, b/c the newest series 3’s require IOS 14! If I do the screen replacement as shown here, do the new parts dictate that the phone have an ios 14? (it says 12 here, but I’m skeptical, only because new series 3 watches won’t work with IOS 12). I assume it depends on other internals, and this should all work, but would appreciate confirmation. Thanks
joe - 回复
I have a question about changing the LCD on my cracked Apple Watch series 3. All of the series 3 replacement screens I have seen are super expensive and are almost as much as getting a new watch. Can I use a replacement lcd for series 1 watch, on my series 3 watch?
Annajorg - 回复
Tobias - I have a GPS only series 3 watch: I cracked the screen and I’m shopping around online, but I was wondering… are the screens the same for GPS and GPS + LTE? It seems very hard to find a GPS-only screen from the descriptions I’m seeing…..?
Amy Halfacre - 回复
I purchased the GPS series 3 watch screen replacement with the force touch gasket replacement. I changed both the screen and force touch gasket, but the watch only restarts to the apple symbol. I have tried to do hard reboot and this didn’t fix it and I did a hard boot while it charged.
Do you have other suggestions?
Josh Robinson - 回复
Will replacing the NFC have an impact on if the digitizer works (although I’m aware that that the NFC isn’t responsible for the digitizer). I replaced the screen on the 42mm Series 3 and it boots up fine but the touch doesn’t work. I contacted the company I bought the screen from and they told me that replacing the NFC will make the digitizer work, but I really don’t want to dink around with the NFC chip unless I absolutely have to…
Grace Wong - 回复
Can the watch be repaired with a series 1 or 2 screen ?
hakarou321 - 回复
Not with the Series 1. If you really want to try a Series 2 display on a Series 3 Watch, take a look at this user generated guide and its comments.
Tobias Isakeit -
I repaired my series 3 with an ifixit screen protector. Admittedly, I didn’t disconnect the battery first, the tutorial didn’t show how to do it for a cellular version. After finishing the replacement, I only get the apple logo. It was coming up on my FindMy, but still stuck on the apple loop after multiple resets. I decided to erase all content and reboot, and now i’m in the same position but I can’t see it on my phone or computer anymore.
I realized maybe it was something to do with my installation, so I removed the screen again, this time fully removed the battery, and reassembled. I’m in the same position being stuck in the apple loop. Does anybody have any suggestions? I’m letting the battery run out, but I don’t really know what else to do here. Leaving the screen connected but not sealed in case any tinkering may help.
Nik Carpentieri - 回复
Hello, i have the same problem, did you manage to solve it? If yes then how?
Dacian Bujor -
Hi, I change the screen for a new one and now it just won’t turn on won’t do anything can you guys help me ?
hakarou321 - 回复
I changed the screen and made sure everything was properly put back but now my touch is not working at all.
Essaud Hernandez - 回复
Hello
I am looking to attempt this with a known good OEM display.
Can anyone confirm this is applicable and worked for them?
Replacing the display can cause issues with Apple Pay. If possible, to reduce the likelihood of problems, delete all your Apple Pay account info before the replacement, and then re-enter it with the new display installed.
Thanks
James - 回复
It’s say that this process was going to be bed hard and in less then 2 hours I replaced the screen of my Apple Watch series 6 and am just 15 years old
Andrew Cruz - 回复
Has anyone tried replacing 42mm watch with 38mm lcd? any luck?
amiralli hemani - 回复
I have a series 3 Apple Watch running watchOS 8.1 when I try to boot with the new display it hangs and shuts off but with the original display it works fine Edit - it started working after I waited a while while plugged I
Thing - 回复
Trying to determine if this series 3 is fixable, obviously needs new screen but don’t know about this other part that appears damaged(top of inside watch gold connector above battery). What is it? Is it replaceable?
Samuel Coleman - 回复
Can I use an iSesamo or any thin metal pry tool to open the screen without any damage?
robbert lambada - 回复
添加评论
浏览统计数据:
过去 24 小时: 44
过去 7 天: 387
过去 30 天: 1,692
总计 365,788
