简介
使用本指南更换 Apple Watch Series 2 的粘合剂并重新密封。在更换之后,Apple Watch的防水性可能无法完全恢复。
你所需要的
29等其他人完成本指南。
由衷感谢以下译者:
66%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
7条评论
My adhesive gasket I ordered from you doesn’t not look like the one you use. I don’t see how it could work either.
My adhesive was larger than the rim so it had about 5-6 mm bump of extra plastic when I got it in the edge all around. Need it to be sealed so I didn't want to cut anything. Fail.
Kevin Male - 回复
Yes mine was also larger than the adhesive seal that is advertised here.
We believe this adhesive kit does not work all the time. there is still risk that with slightly water in-contact during activity, screen may slightly raised again. I think using glue E-8000 after wiping the edges of the watch with isopropyl is a good idea for long term safety.
iRepairMan - 回复
The Tesa adhesives that you sent are simply aweful. The cuts aren’t deep enough to safely remove the replacement adhesive with the blue protective film from the backing paper. Plus when you actually manage to do so, the adhesive’s dimensions are a bit short for the Series 3 42mm model.
