跳转到主内容
本篇指南是分解流程而非维修指南。 如果您要维修您的Apple Watch SE,应参考我们的维修指南
  1. Apple Watch SE Mother Board Removal, Removing the Taptic Engine: 步骤 1 中的图像 1,2 Apple Watch SE Mother Board Removal, Removing the Taptic Engine: 步骤 1 中的图像 2,2
    • Unscrew Tri-screw and remove small plate cover.
    • Then, remove these two Tri-screws.
  2. Apple Watch SE Mother Board Removal, Removing the Taptic Engine pt. 2: 步骤 2 中的图像 1,3 Apple Watch SE Mother Board Removal, Removing the Taptic Engine pt. 2: 步骤 2 中的图像 2,3 Apple Watch SE Mother Board Removal, Removing the Taptic Engine pt. 2: 步骤 2 中的图像 3,3
    • Undo both connectors highlighted.
    • Then the Taptic engine should be able to be lifted out.
    • The Taptic engine has some adhesive on the cable outlined in blue that sticks it to the speaker.
  3. Apple Watch SE Mother Board Removal, Removing the Speaker: 步骤 3 中的图像 1,3 Apple Watch SE Mother Board Removal, Removing the Speaker: 步骤 3 中的图像 2,3 Apple Watch SE Mother Board Removal, Removing the Speaker: 步骤 3 中的图像 3,3
    • Disconnect this connector.
    • Then remove these 3 tri-screws.
  4. Apple Watch SE Mother Board Removal, Removing the Speaker pt. 2: 步骤 4 中的图像 1,2 Apple Watch SE Mother Board Removal, Removing the Speaker pt. 2: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the speaker slowly.
    • Where my tweezers are located seems to be the best place to remove the speaker.
  5. Apple Watch SE Mother Board Removal, Removing Brackets around the MB: 步骤 5 中的图像 1,3 Apple Watch SE Mother Board Removal, Removing Brackets around the MB: 步骤 5 中的图像 2,3 Apple Watch SE Mother Board Removal, Removing Brackets around the MB: 步骤 5 中的图像 3,3
    • 4 more Tri-screws are removed here.
    • Gently pulling back the screen flex cables reveals 2 more Tri-screws that should be removed.
    • Then the brackets can be removed with tweezers.
  6. Apple Watch SE Mother Board Removal, Removing Brackets around the Power Button: 步骤 6 中的图像 1,2 Apple Watch SE Mother Board Removal, Removing Brackets around the Power Button: 步骤 6 中的图像 2,2
    • Remove these 2 Tri-screws.
    • After taking off the first bracket, take of the next Tri-screw and remove the second bracket.
  7. Apple Watch SE Mother Board Removal, Disconnecting Power button: 步骤 7 中的图像 1,2 Apple Watch SE Mother Board Removal, Disconnecting Power button: 步骤 7 中的图像 2,2
    • Disconnect the Power button FPC.
    • The FPC here has 2 connections. DO NOT pry in the middle as it may bend.
  8. Apple Watch SE Mother Board Removal, Removing the MB.: 步骤 8 中的图像 1,3 Apple Watch SE Mother Board Removal, Removing the MB.: 步骤 8 中的图像 2,3 Apple Watch SE Mother Board Removal, Removing the MB.: 步骤 8 中的图像 3,3
    • Starting in the bottom right corner as show here. Gently wedge in a spudger and pry up on the board.
    • Once you are able to get a good hold on the board move try pulling down and to the right in a clockwork motion.
    • Do this motion slowly as there is a final connector under the board.
  9. Apple Watch SE Mother Board Removal, Completion: 步骤 9 中的图像 1,1
    • Once the board is lifted out, the final connector is highlighted.
    • Disconnect and you are all done!
    • Repeat steps backwards to put everything back together.
jessepugsley
于01/21/20注册
181 声望
撰写一个指南
1指南评论
thank you so much
Wesleyfraga - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 27
过去 30 天: 127
总计 6,427
