跳转到主内容
Apple Watch - Series 10 (46mm) Battery Replacement
你所需要的
  1. Apple Watch - Series 10 (46mm) Battery Replacement, Prepare your watch for disassembly: 步骤 1 中的图像 1,2 Apple Watch - Series 10 (46mm) Battery Replacement, Prepare your watch for disassembly: 步骤 1 中的图像 2,2
    • Before starting this repair, remove your watch from the charger and let its battery drain completely—the watch should shut down from low battery. A charged lithium‑ion battery may catch fire if damaged.
    • Letting the battery drain completely also prevents accidentally turning your watch back on when gripping it during repair.
  2. Apple Watch - Series 10 (46mm) Battery Replacement, Disassembly information: 步骤 2 中的图像 1,3 Apple Watch - Series 10 (46mm) Battery Replacement, Disassembly information: 步骤 2 中的图像 2,3 Apple Watch - Series 10 (46mm) Battery Replacement, Disassembly information: 步骤 2 中的图像 3,3
    • Throughout the rest of your repair:
    • Attach and remove the watch bands as needed to get a better grip or stabilize your watch.
    • To remove a band, firmly press in the small, oval button on the underside of the watch and slide the band out of its groove.
    • Consider placing your watch on something soft like a clean cloth to help stabilize it and prevent damage.
  3. Apple Watch - Series 10 (46mm) Battery Replacement, Mark your opening picks: 步骤 3 中的图像 1,3 Apple Watch - Series 10 (46mm) Battery Replacement, Mark your opening picks: 步骤 3 中的图像 2,3 Apple Watch - Series 10 (46mm) Battery Replacement, Mark your opening picks: 步骤 3 中的图像 3,3
    • If inserted too far, an opening pick can damage your watch. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. Apple Watch - Series 10 (46mm) Battery Replacement, Heat the screen: 步骤 4 中的图像 1,1
    • Strong adhesive secures the perimeter of the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
    • Heat an iOpener and lay it on the screen for two minutes to soften its adhesive.
    • Alternatively, you can use a hair dryer or heat gun—but be careful as extreme heat can damage the screen and/or battery.
  5. Apple Watch - Series 10 (46mm) Battery Replacement, Insert an iFlex: 步骤 5 中的图像 1,3 Apple Watch - Series 10 (46mm) Battery Replacement, Insert an iFlex: 步骤 5 中的图像 2,3 Apple Watch - Series 10 (46mm) Battery Replacement, Insert an iFlex: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    iFlex Opening Tool
    $11.99
    • The gap between the screen and frame is extremely small. You'll need a thin tool such as an iFlex to create an initial gap.
    • Don't grip the iFlex or similar metal tools by the edges—they're very sharp. Consider wearing gloves to protect your hands.
    • Insert the iFlex at a downward angle between the bottom edge of the screen and frame.
  6. Apple Watch - Series 10 (46mm) Battery Replacement, Pry up the screen: 步骤 6 中的图像 1,2 Apple Watch - Series 10 (46mm) Battery Replacement, Pry up the screen: 步骤 6 中的图像 2,2
    • Prying up the screen may take multiple attempts. If you're having trouble, apply more heat and try again.
    • With one hand, push down firmly on the watch's frame to secure it in place.
    • With your free hand, hold the iFlex and push the edges up to make it more rigid.
    • The iFlex should be slightly "U" shaped.
    • Pry up the screen enough for the iFlex to lay flat on its own.
    • The iFlex doesn't need to be inserted far, as it can easily damage the screen cables near the bottom right corner of the watch.
    • Leave the iFlex inserted under the screen.
  7. Apple Watch - Series 10 (46mm) Battery Replacement, Insert an opening pick: 步骤 7 中的图像 1,3 Apple Watch - Series 10 (46mm) Battery Replacement, Insert an opening pick: 步骤 7 中的图像 2,3 Apple Watch - Series 10 (46mm) Battery Replacement, Insert an opening pick: 步骤 7 中的图像 3,3
    • Do not insert your opening pick more than 3 mm under the screen when separating the adhesive, as you risk damaging your watches internals.
    • Keep the iFlex flat to maintain a gap between the screen and frame while inserting an opening pick.
    • Insert an opening pick between the screen and iFlex.
    • Remove the iFlex.
  8. Apple Watch - Series 10 (46mm) Battery Replacement, Separate the screen adhesive: 步骤 8 中的图像 1,3 Apple Watch - Series 10 (46mm) Battery Replacement, Separate the screen adhesive: 步骤 8 中的图像 2,3 Apple Watch - Series 10 (46mm) Battery Replacement, Separate the screen adhesive: 步骤 8 中的图像 3,3
    • Slide the opening pick around the bottom left corner and up the left edge.
  9. Apple Watch - Series 10 (46mm) Battery Replacement: 步骤 9 中的图像 1,2 Apple Watch - Series 10 (46mm) Battery Replacement: 步骤 9 中的图像 2,2
    • Continue sliding your pick along the top edge and around the top right corner, stopping just after the digital crown.
    • Don't slide your pick past the digital crown—you risk damage to the screen cables.
  10. Apple Watch - Series 10 (46mm) Battery Replacement, Separate the remaining adhesive: 步骤 10 中的图像 1,2 Apple Watch - Series 10 (46mm) Battery Replacement, Separate the remaining adhesive: 步骤 10 中的图像 2,2
    • Insert the long edge of an opening pick between the left edge of the screen and frame.
    • Twist the pick to lift the screen and separate any remaining adhesive.
  11. Apple Watch - Series 10 (46mm) Battery Replacement, Swing open the screen: 步骤 11 中的图像 1,3 Apple Watch - Series 10 (46mm) Battery Replacement, Swing open the screen: 步骤 11 中的图像 2,3 Apple Watch - Series 10 (46mm) Battery Replacement, Swing open the screen: 步骤 11 中的图像 3,3
    • Pull the right edge of the screen over the digital crown.
    • If the screen feels stuck, go back around it with an opening pick to separate any adhesive.
    • Swing up the left edge of the screen so it's upright. The screen should be to the right of the digital crown.
    • During reassembly:
    • This is a good point to plug in your watch and test all functions before sealing it up. Be sure to power it back down completely before you continue working.
    • Follow this guide to apply new screen adhesive and reseal your watch.
  12. Apple Watch - Series 10 (46mm) Battery Replacement, Remove the battery connector screw: 步骤 12 中的图像 1,2 Apple Watch - Series 10 (46mm) Battery Replacement, Remove the battery connector screw: 步骤 12 中的图像 2,2
    • Use a tri‑point Y000 screwdriver to remove the 1.1 mm‑long screw securing the battery connector bracket.
  13. Apple Watch - Series 10 (46mm) Battery Replacement, Remove the bracket: 步骤 13 中的图像 1,2 Apple Watch - Series 10 (46mm) Battery Replacement, Remove the bracket: 步骤 13 中的图像 2,2
    • Use tweezers to remove the battery connector bracket.
    • During reassembly, make sure the longer section of the bracket goes over the battery press connector.
  14. Apple Watch - Series 10 (46mm) Battery Replacement, Disconnect the battery: 步骤 14 中的图像 1,2 Apple Watch - Series 10 (46mm) Battery Replacement, Disconnect the battery: 步骤 14 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the battery press connector.
  15. Apple Watch - Series 10 (46mm) Battery Replacement, Heat the battery adhesive: 步骤 15 中的图像 1,1
    • Heating the battery will soften the strong adhesive securing it, making the battery easier to remove.
    • Heat an iOpener and lay it on the battery for two minutes to soften the adhesive.
    • Alternatively, you can use a hair dryer or heat gun—but be careful as extreme heat can damage the battery.
  16. Apple Watch - Series 10 (46mm) Battery Replacement, Pry up the battery: 步骤 16 中的图像 1,3 Apple Watch - Series 10 (46mm) Battery Replacement, Pry up the battery: 步骤 16 中的图像 2,3 Apple Watch - Series 10 (46mm) Battery Replacement, Pry up the battery: 步骤 16 中的图像 3,3
    • Be careful not to puncture or bend the battery—it can leak dangerous chemicals and catch fire.
    • Insert an opening pick between the bottom edge of the battery and frame.
    • Pry up the battery with the opening pick until it starts to separate from the frame.
    • This requires time and constant pressure. If you're having trouble, apply more heat and try again.
    • Slide the pick farther under the battery and lift until all the adhesive is separated.
  17. Apple Watch - Series 10 (46mm) Battery Replacement, Remove the battery: 步骤 17 中的图像 1,3 Apple Watch - Series 10 (46mm) Battery Replacement, Remove the battery: 步骤 17 中的图像 2,3 Apple Watch - Series 10 (46mm) Battery Replacement, Remove the battery: 步骤 17 中的图像 3,3
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $2.99
    • Remove the battery from the frame.
    • To install a new battery:
    • Use a spudger and tweezers to remove all the old adhesive from the battery recess.
    • If your replacement battery doesn't have adhesive pre-installed, put strips of thin, double-sided tape on the logic board (not directly on the battery) where the old adhesive was.
    • Reconnect the battery cable press connector to its socket on the motherboard.
    • Remove any liners from the battery adhesive or double-sided tape.
    • Firmly press the battery into place to secure it with the adhesive.
结论
For optimal performance, calibrate your newly installed battery after completing your repair.
2等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
212,632 声望
创作了1,039篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,608篇指南
1指南评论
This was a great walk-thru for a battery replacement, thanks for all you do!
Deeno - 回复
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 131
过去 30 天: 550
总计 4,597
