本指南有最近更改,您可查看未经巡查的最新版本。
简介
The Logic Board is like the central nervous system of the Time Capsule. Without the Logic Board the device will not function. The Ethernet ports are attached to the Logic Board, so if one port is damaged then you must replace the whole board. Use this guide to easily replace the damaged component.
你所需要的
Turn the device upside down to reveal the rubber section of the back plate. Using a metal spudger, carefully wedge the blunt tip into the space between the aluminum back plate and the rubber, separating the two pieces.
Depending on air temperature and how set the adhesive is, you may need to spend some time warming the back plate with a hot plate (on low) or hair dryer.
Remove the external connector from its housing by lifting it up, then out.
Lift the internal power supply brick out of the device.
Peel off the adhesive backed foam from the top of the drive.
Lift the drive straight up and out of the device.
Remove the three 4mm screws from the base of the board with a Phillips #0 screwdriver.
7等其他人完成本指南。
2条评论
Between step 12 and 13 there is no detail on how to remove the board! I did the procedure until step #12 but board is firmly attached to the case! even after pullling the metal tabs it’s still glued to the base, please help
The board seems stuck because of sticky thermal pads between the chips and the housing. Assuming all screws are removed and cables disconnected, you should be able to pull up the board by just applying force. Hope this helps.
