跳转到主内容
Apple Time Capsule Model A1254 Hard Drive Replacement
你所需要的
  1. Apple Time Capsule Model A1254 Hard Drive Replacement, Back Plate: 步骤 1 中的图像 1,3 Apple Time Capsule Model A1254 Hard Drive Replacement, Back Plate: 步骤 1 中的图像 2,3 Apple Time Capsule Model A1254 Hard Drive Replacement, Back Plate: 步骤 1 中的图像 3,3
    • Turn the device upside down to reveal the rubber section of the back plate. Using a metal spudger, carefully wedge the blunt tip into the space between the aluminum back plate and the rubber, separating the two pieces.
    • This may take a few minutes to pry the rubber off completely. Once your are able to get a grip on the rubber it is easier to peel it off using your hands.
    • Depending on air temperature and how set the adhesive is, you may need to spend some time warming the back plate with a hot plate (on low) or hair dryer.
    • Don't worry about re-applying adhesive to the rubber; the remaining adhesive has plenty of strength to affix itself to the aluminum.
  2. Apple Time Capsule Model A1254 Hard Drive Replacement: 步骤 2 中的图像 1,2 Apple Time Capsule Model A1254 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Remove the ten 3mm screws with a Phillips #00 screwdriver.
    • The screws with adhesive covering do not need to be removed.
  3. Apple Time Capsule Model A1254 Hard Drive Replacement: 步骤 3 中的图像 1,2 Apple Time Capsule Model A1254 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • The fan affixed to the back plate is connected to the logic board. A small wire must be detached to fully remove the back plate.
    • Pull the base of the wire close to the logic board and the connector will pop off.
  4. Apple Time Capsule Model A1254 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Peel off the adhesive backed foam from the top of the drive.
    • Lift the drive straight up and out of the device.
  5. Apple Time Capsule Model A1254 Hard Drive Replacement: 步骤 5 中的图像 1,3 Apple Time Capsule Model A1254 Hard Drive Replacement: 步骤 5 中的图像 2,3 Apple Time Capsule Model A1254 Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Remove the SATA connector and power connector from the end of the hard drive by simply pulling the cables straight away from the connection points.
结论
34等其他人完成本指南。
Patrick Butler
于10/06/16注册
1,145 声望
创作了2篇指南
团队
Cal Poly, Team 4-2, Livingston Fall 2016 Cal Poly, Team 4-2, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S4G2
4 名成员
创作了17篇指南
11指南评论
What’s the max hard drive a Time Machine can take?
ice2257 - 回复
This answer: What's the biggest HDD that will fit on my Time Capsule? suggests that you can use pretty much any available drive. If it could take a 4TB in 2014 (one of the answers), I don’t think there would be any limit practically speaking.
odaiwai - 回复
Great guide. One note. My unit was quite old and the rubber mat was brittle. Even with a heat gun and spudger I still tore it in several places. This might be avoided by heating up a cloth in a microwave first and applying it to the rubber before beginning to pull it off. Just a thought.
wfstapleton - 回复
I’m not seeing a guide for the Apple Time Capsule 2TB MC344LLA / A1355 so I’ll have to see which one is closer to my model when it arrives,
But in the meantime has anyone been able to upgrade the hard drive past 2TB without any issues?
Is a Firmware update needed to do so?
David Bell - 回复
I installed a 3 TB about 7 years ago in mine. i’m here now because I can’t get it to power on.
Nubs34 -
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 60
过去 30 天: 275
总计 23,520
