跳转到主内容
Apple Thunderbolt Display Webcam and Mic Replacement
你所需要的
  1. Apple Thunderbolt Display Webcam and Mic Replacement, LCD: 步骤 1 中的图像 1,3 Apple Thunderbolt Display Webcam and Mic Replacement, LCD: 步骤 1 中的图像 2,3 Apple Thunderbolt Display Webcam and Mic Replacement, LCD: 步骤 1 中的图像 3,3
    • Lay down the display with screen side up.
    • Since the display is able to be tilted up and down, we found it useful to prop up the screen up with a styrofoam block in between the screen and the base.
    • Place the two suction cups on both sides of the top of the screen and make sure to lock them in place.
    • The glass screen is connected to the rest of the display by small magnets. Lift slowly and the screen will come right off.
  2. Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 2 中的图像 1,2 Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 2 中的图像 2,2
    • Unscrew the 12 screws around the side edges and the top of the LCD with the TR 10 Screwdriver.
  3. Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 3 中的图像 1,2 Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 3 中的图像 2,2
    • Slowly lift the LCD out from its placement and tilt it upwards.
    • It can be very helpful to have an extra set of hands to hold the LCD up while you work with the cables underneath.
    • There are four wires that connect the LCD to the rest of the components. Make sure not to pull hard and break any of the wires.
  4. Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 4 中的图像 1,3 Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 4 中的图像 2,3 Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 4 中的图像 3,3
    • For the first of the four wires (furthest away from the wire that is held in by a screw), grab onto the connector and pull slowly.
  5. Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 5 中的图像 1,3 Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 5 中的图像 2,3 Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 5 中的图像 3,3
    • For the next connector, which is right next to the previous wire, there is a piece of tape attached to a metal bar.
    • Flip the metal bar over using the tape as a handle.
    • Next, grab onto the connector and slowly pull it from the socket in the logic board.
  6. Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 6 中的图像 1,3 Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 6 中的图像 2,3 Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 6 中的图像 3,3
    • For the connector on the other side of the logic board, grab the connector from underneath and carefully pull it from the board.
  7. Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 7 中的图像 1,1
    • For the last wire connecting to the LCD, use your T 10 Screwdriver to remove the screw.
  8. Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 8 中的图像 1,2 Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 8 中的图像 2,2
    • The LCD has now been fully disconnected from the casing and can be repaired/replaced!
    • its best to set the LCD on a bed or on a thick towel to avoid damage to the LCD
  9. Apple Thunderbolt Display Webcam and Mic Replacement, Webcam and Mic: 步骤 9 中的图像 1,3 Apple Thunderbolt Display Webcam and Mic Replacement, Webcam and Mic: 步骤 9 中的图像 2,3 Apple Thunderbolt Display Webcam and Mic Replacement, Webcam and Mic: 步骤 9 中的图像 3,3
    • The webcam and microphone are located at the top of the device. First, follow the white microphone wire down to its connector in the logic board.
    • Carefully pull the white wire's connector from the logic board.
  10. Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 10 中的图像 1,2 Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 10 中的图像 2,2
    • Follow the wire down from the webcam and find where it is connected into the logic board.
    • Carefully remove the connector from the logic board.
  11. Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 11 中的图像 1,2 Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    • The wires are held in place by three pieces of tape. Remove the tape out of the way so that the wires are free.
    • It is very easy to remove the pieces of tape using tweezers. They aren't completely necessary though.
  12. Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 12 中的图像 1,2 Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 12 中的图像 2,2
    • Back at the top of the device, there are two pieces of silver tape holding the webcam wires in place.
    • Again, tweezers are helpful but aren't necessary for removal of the silver tape.
    • Next, remove the tape that is holding the microphone in place.
  13. Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 13 中的图像 1,3 Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 13 中的图像 2,3 Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 13 中的图像 3,3
    • The webcam is held in with two screws and a connector
    • Unscrew the two screws holding the webcam in place with the TR 10 screwdriver.
    • The webcam is now free from your display!
  14. Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 14 中的图像 1,2 Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 14 中的图像 2,2
    • With the webcam removed, the microphone is now visible.
    • The webcam is held in place with a plastic clip that has foam adhesive stuck to the casing.
    • Use a plastic spudger to pry underneath the clip and separate the clip from the casing.
  15. Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 15 中的图像 1,2 Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 15 中的图像 2,2
    • The actual microphone itself is stuck to the top of the casing using a small amount of adhesive and covered by a piece of tape.
    • Remove the piece of tape using either tweezers or your fingers to have access to the microphone.
    • Use the plastic spudger again to get underneath the small round microphone and pry it loose from the adhesive.
  16. Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 16 中的图像 1,2 Apple Thunderbolt Display Webcam and Mic Replacement: 步骤 16 中的图像 2,2
    • The wires for both the webcam and the microphone are tucked underneath a few other components.
    • Carefully pull the wires out up and out from the other components and your webcam and microphone can be replaced.
结论
4等其他人完成本指南。
Wesley Ho
于04/14/15注册
463 声望
撰写一个指南
团队
Cal Poly, Team 5-11, Maness Spring 2015 Cal Poly, Team 5-11, Maness Spring 2015 的会员
CPSU-MANESS-S15S5G11
4 名成员
创作了20篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 33
总计 4,286
