跳转到主内容
Apple TV 4K Remote Battery/Charging Port Replacement
你所需要的
  1. Apple TV 4K Remote Battery/Charging Port Replacement, Remote Battery, Charging Port: 步骤 1 中的图像 1,1
    • Heat iOpener according to manufacturer's instructions.
    • Place over the face of the remote to soften the adhesive under the glass.
  2. Apple TV 4K Remote Battery/Charging Port Replacement: 步骤 2 中的图像 1,2 Apple TV 4K Remote Battery/Charging Port Replacement: 步骤 2 中的图像 2,2
    • Using a spudger, gently lift the face of the remote. Starting from the bottom and working your way to the top.
  3. Apple TV 4K Remote Battery/Charging Port Replacement: 步骤 3 中的图像 1,1
    • Push front face forward to disengage plastic clips at the top of the remote.
  4. Apple TV 4K Remote Battery/Charging Port Replacement: 步骤 4 中的图像 1,1
    • Unlatch the connector that binds the touch screen and logic board.
  5. Apple TV 4K Remote Battery/Charging Port Replacement: 步骤 5 中的图像 1,1
    • Use tweezers to pull off the connector that binds the touch screen to the logic board.
  6. Apple TV 4K Remote Battery/Charging Port Replacement: 步骤 6 中的图像 1,1
    • Lift the face from the body of the remote.
  7. Apple TV 4K Remote Battery/Charging Port Replacement: 步骤 7 中的图像 1,2 Apple TV 4K Remote Battery/Charging Port Replacement: 步骤 7 中的图像 2,2
    • Lift the latch holding back the connector to the battery.
    • Use tweezers to disconnect the battery connector.
  8. Apple TV 4K Remote Battery/Charging Port Replacement: 步骤 8 中的图像 1,1
    • Remove the following screws using a T3 Torx screwdriver:
    • Eight 2mm screws
  9. Apple TV 4K Remote Battery/Charging Port Replacement: 步骤 9 中的图像 1,1
    • Using a plastic spudger, gently remove the logic board from the case of the remote.
  10. Apple TV 4K Remote Battery/Charging Port Replacement: 步骤 10 中的图像 1,2 Apple TV 4K Remote Battery/Charging Port Replacement: 步骤 10 中的图像 2,2
    • Gently dislodge the battery from the remote case, making sure to avoid damaging the battery itself.
    • The battery should be fully removed now.
结论
17等其他人完成本指南。
Keenan Barber
于10/04/18注册
1,159 声望
创作了3篇指南
团队
UW Stout, Team S6-G3, Ogden Fall 2018 UW Stout, Team S6-G3, Ogden Fall 2018 的会员
UWSTOUT-OGDEN-F18S6G3
4 名成员
创作了15篇指南
7条评论
Great but can you explain how and what to use to seal it back.
With out sealing it not working properly
Thanks
Iva Sh - 回复
Hi there, where can you buy the actual battery replacement?… any links?
RLinhares - 回复
I second this. It would be great if someone could link us on where to buy the battery/charger replacement.
_ Dubb -
You won’t be able to source the original battery as it is spot welded to the lightning port cable and mobo cable, and is one unit. However if you can solder I have successfully replaced two remote batteries for about $6-$8 a battery.
sinkproductions -
I’ve searched high and low for this battery as mine will not maintain a charge for more than a few hours. I found this one for a Huawei watch: https://www.batteryclub.org/Goods/ECN106... that appears to be the correct specs, but I’m not sure it can be connected.
That noted, a new remote is only $52 and this battery is $39.50 plus shipping! So for my money a new remote is a better option since we know it will work, and it’s just $12 or so more! Nuts!
pgrobin - 回复
添加评论
浏览统计数据:
过去 24 小时: 27
过去 7 天: 288
过去 30 天: 1,419
总计 81,672
