跳转到主内容
Apple TV 4K Logic Board Replacement
你所需要的
  1. Apple TV 4K Logic Board Replacement, Logic Board: 步骤 1 中的图像 1,1
    • Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
    • The panel is held onto the device tightly, so you may need to be a bit forceful to remove it.
  2. Apple TV 4K Logic Board Replacement: 步骤 2 中的图像 1,2 Apple TV 4K Logic Board Replacement: 步骤 2 中的图像 2,2
    • Remove the following screws using a T6 Torx screwdriver holding the heat sink assembly in.
    • Four 10 mm screws
    • Lift and remove the heat sink assembly from the device.
  3. Apple TV 4K Logic Board Replacement: 步骤 3 中的图像 1,2 Apple TV 4K Logic Board Replacement: 步骤 3 中的图像 2,2
    • Use plastic spudger to pull up on all three antenna connectors to remove them.
    • Remove rubber piece from front side of device.
  4. Apple TV 4K Logic Board Replacement: 步骤 4 中的图像 1,1
    • Unscrew the following screws holding the logic board in place using the T7 Torx:
    • Two black 3 mm screws
    • Two silver 4 mm screws
  5. Apple TV 4K Logic Board Replacement: 步骤 5 中的图像 1,3 Apple TV 4K Logic Board Replacement: 步骤 5 中的图像 2,3 Apple TV 4K Logic Board Replacement: 步骤 5 中的图像 3,3
    • Use a spudger to pry up logic board. Try lifting it up from the front side.
    • Remove logic board and set aside.
结论
8等其他人完成本指南。
Keenan Barber
于10/04/18注册
1,159 声望
创作了3篇指南
团队
UW Stout, Team S6-G3, Ogden Fall 2018 UW Stout, Team S6-G3, Ogden Fall 2018 的会员
UWSTOUT-OGDEN-F18S6G3
4 名成员
创作了15篇指南
8条评论
Where does one get a new logic board??
MP94025 - 回复
Any idea on where I can purchase. new logic board?
tylerchumchal - 回复
Where do you buy the board…….
Andy Grichtmeier - 回复
Good job on showing how to remove and replace logic board. Now as the other three commentators have asked
, where can you buy another one or is an exercise in futility
Kanehoe - 回复
Hm. Has anyone’s Apple TV 4k logic board failed?
oTWR - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 26
过去 30 天: 118
总计 8,129
