跳转到主内容
Apple TV 3rd Generation Status LED Replacement
你所需要的
  1. Apple TV 3rd Generation Status LED Replacement, Snap-on Base: 步骤 1 中的图像 1,1
    • As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
  2. Apple TV 3rd Generation Status LED Replacement: 步骤 2 中的图像 1,1
    • Continue releasing the last plastic clips with your hands taking care not to break any of the plastic elements attached to the base.
  3. Apple TV 3rd Generation Status LED Replacement, Logic Board: 步骤 3 中的图像 1,1
    • Use a philips screwdriver to remove the 5 screws securing the metal heat sink. On Rev A (A1469) you need a T7 srewdriver
  4. Apple TV 3rd Generation Status LED Replacement: 步骤 4 中的图像 1,2 Apple TV 3rd Generation Status LED Replacement: 步骤 4 中的图像 2,2
    • Disconnect the power supply connector from the logic board with a spudger.
  5. Apple TV 3rd Generation Status LED Replacement, Power Supply: 步骤 5 中的图像 1,2 Apple TV 3rd Generation Status LED Replacement, Power Supply: 步骤 5 中的图像 2,2
    • Before you remove completely the power supply, unscrew the T6 screws on each side of the socket.
    • You may now be able to remove the power supply with a spudger.
    • Do not pull the wires to remove the power supply. The connector is fragile.
    • The rating of the power supply is 3.4V at 1.75A, which is identical to the 2nd Gen Apple TV's 5.95 watts.
  6. Apple TV 3rd Generation Status LED Replacement, Status LED: 步骤 6 中的图像 1,2 Apple TV 3rd Generation Status LED Replacement, Status LED: 步骤 6 中的图像 2,2
    • The last remaining part in the Apple TV is the status LED. You can remove this part with your plastic spudger.
结论
4等其他人完成本指南。
Vincent Monteil
于07/06/13注册
7,023 声望
创作了19篇指南
1指南评论
Step 2: “caring not to break….”. Thanks, great guide. David
David Apimerika - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 17
总计 3,297
