跳转到主内容
Apple TV 3rd Generation Logic Board Replacement
你所需要的
  1. Apple TV 3rd Generation Logic Board Replacement, Snap-on Base: 步骤 1 中的图像 1,1
    • As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
    where so i find a new base to replace it with
    sharpeEZz - 回复
  2. Apple TV 3rd Generation Logic Board Replacement: 步骤 2 中的图像 1,1
    • Continue releasing the last plastic clips with your hands taking care not to break any of the plastic elements attached to the base.
  3. Apple TV 3rd Generation Logic Board Replacement, Logic Board: 步骤 3 中的图像 1,1
    • Use a philips screwdriver to remove the 5 screws securing the metal heat sink. On Rev A (A1469) you need a T7 srewdriver
  4. Apple TV 3rd Generation Logic Board Replacement: 步骤 4 中的图像 1,2 Apple TV 3rd Generation Logic Board Replacement: 步骤 4 中的图像 2,2
    • Disconnect the power supply connector from the logic board with a spudger.
结论
10等其他人完成本指南。
Vincent Monteil
于07/06/13注册
6,975 声望
创作了19篇指南
4条评论
Where can I find a 3rd Generation Apple TV Logic Board?
Ricky Vaughn - 回复
Good question! Did you manage to find a replacement?
Nathan Bugeja -
Hi my wifi and athernet is not working in apple tv on screen it showing your apple tv is connected to local network its not connect to internet now how should i repair this
Mohamed Iqbal Sayyed - 回复
Mine too, where could I find a logic board replacement???
Juan Ignacio Gutierrez I. -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 26
总计 9,685
