跳转到主内容
Apple TV 2nd Generation Bottom Cover Replacement
你所需要的
  1. Apple TV 2nd Generation Bottom Cover Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    Metal Spudger
    $2.99
    购买
    • As the Apple TV doesn’t have any visible screws or points of entry, the first step is to use a couple of metal spudger to carefully loosen and remove the rubber base/bottom cover from the upper case.
  2. Apple TV 2nd Generation Bottom Cover Replacement: 步骤 2 中的图像 1,1
    • Position the replacement base over the exposed interior of the Apple TV. Gently press the cover down into the Apple TV until the interior tabs snap into place and the base is attached securely to the upper case.
结论
Areej Bashawiri
于09/28/17注册
201 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 20
总计 1,112
