本指南有最近更改,您可查看未经巡查的最新版本。
简介
Remove the lower case in your Apple TV 1st Generation.
你所需要的
Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
Repeat the procedure described above until the rubber base has been completely removed.
3等其他人完成本指南。
一条评论
This guide may make more sense as a teardown, since its not really showing any repairs or replacements.
