跳转到主内容
Apple TV 1st Generation Lower Case Replacement
你所需要的
  1. Apple TV 1st Generation Lower Case Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Flip the Apple TV over so that the bottom of the unit is facing up.
    • You need to remove the rubber base to get access to the screws.
    • Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
    • The rubber base will be hot after heating, take extreme caution while proceeding to avoid personal injury.
    • While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
    • The rubber base can tear if the adhesive hasn't been softened enough.
    • Repeat the procedure described above until the rubber base has been completely removed.
  2. Apple TV 1st Generation Lower Case Replacement: 步骤 2 中的图像 1,1
    • Remove the four T10 Torx screws that secure the lower case to the upper case.
  3. Apple TV 1st Generation Lower Case Replacement: 步骤 3 中的图像 1,1
    • Carefully lift the lower case from the upper case enough to allow access to the internals of the Apple TV.
    • Be aware that the hard drive is physically attached to the lower case and that a ribbon cable runs from the drive to the logic board in the upper case.
  4. Apple TV 1st Generation Lower Case Replacement: 步骤 4 中的图像 1,2 Apple TV 1st Generation Lower Case Replacement: 步骤 4 中的图像 2,2
    • Carefully pull the hard drive data cable straight up from its socket on the logic board.
    • During reassembly, make sure the hard drive data cable is firmly seated in its socket on the logic board; otherwise, during boot-up you will see a flashing question mark "?".
结论
3等其他人完成本指南。
CCarvalho
于11/08/09注册
283 声望
撰写一个指南
团队
Cal Poly, Team 18-5, Maness Fall 2009 Cal Poly, Team 18-5, Maness Fall 2009 的会员
CPSU-MANESS-F09S18G5
5 名成员
创作了6篇指南
一条评论
This guide may make more sense as a teardown, since its not really showing any repairs or replacements.
Alex Jansen - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 8,393
