本指南有最近更改,您可查看未经巡查的最新版本。
简介
Replace your Apple TV's 1st Generation logic board.
你所需要的
Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
Repeat the procedure described above until the rubber base has been completely removed.
Pry the AirPort antenna cables straight up from their sockets on the logic board.
7等其他人完成本指南。
