跳转到主内容
加入维修社区 - 创建账户
Apple TV 1st Generation Fan Replacement
你所需要的
    1. Apple TV 1st Generation Fan Replacement, Lower Case: 步骤 1 中的图像 1,1
      • Flip the Apple TV over so that the bottom of the unit is facing up.
      • You need to remove the rubber base to get access to the screws.
      • Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
      • The rubber base will be hot after heating, take extreme caution while proceeding to avoid personal injury.
      • While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
      • The rubber base can tear if the adhesive hasn't been softened enough.
      • Repeat the procedure described above until the rubber base has been completely removed.
      询问修复机器人
      添加评论
    2. Apple TV 1st Generation Fan Replacement: 步骤 2 中的图像 1,1
      • Remove the four T10 Torx screws that secure the lower case to the upper case.
      询问修复机器人
      添加评论
    3. Apple TV 1st Generation Fan Replacement: 步骤 3 中的图像 1,1
      • Carefully lift the lower case from the upper case enough to allow access to the internals of the Apple TV.
      • Be aware that the hard drive is physically attached to the lower case and that a ribbon cable runs from the drive to the logic board in the upper case.
      询问修复机器人
      添加评论
    4. Apple TV 1st Generation Fan Replacement: 步骤 4 中的图像 1,2 Apple TV 1st Generation Fan Replacement: 步骤 4 中的图像 2,2
      • Carefully pull the hard drive data cable straight up from its socket on the logic board.
      • During reassembly, make sure the hard drive data cable is firmly seated in its socket on the logic board; otherwise, during boot-up you will see a flashing question mark "?".
      询问修复机器人
      添加评论
    1. Apple TV 1st Generation Fan Replacement, Fan: 步骤 5 中的图像 1,1
      在这个步骤中使用的工具:
      • The fan is held in place by three rubber posts.
      • Using a pair of tweezers, squeeze the top of each post and push the post down into the hole. Repeat for all three posts.
      • During reinstallation, it helps to lubricate the rubber posts. Try weaving a string through the holes in the posts to pull them up through the mounting points.
      • Do not excessively pull on the posts, as they may rip.
      询问修复机器人
      添加评论
    2. Apple TV 1st Generation Fan Replacement: 步骤 6 中的图像 1,1
      • Using a pair of tweezers, pull the fan connector straight up from its socket on the logic board.
      • Lift and remove the fan out of the upper case.
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
ropel
于11/11/09注册
119 声望
创作了2篇指南
团队
Cal Poly, Team 18-5, Maness Fall 2009 Cal Poly, Team 18-5, Maness Fall 2009 的会员
CPSU-MANESS-F09S18G5
5 名成员
创作了25篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 54
总计 12,601
