当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Rotate the display so the legs of the display are now facing you
Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
Now that the screw has been removed, slide the panel towards your body and lift it out.
You may need to remove the clear USB port cover to remove the metal EMI shield.
To remove the USB port, remove these four screws holding down the port and metal brackets.
There may be a zip tie you need to cut that is attaching the USB unit to the display
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
