简介
Replacing the inverter, a common cause for what looks to be a loss of backlight.
你所需要的
Lay the display facing down with the stand away from you.
Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
5等其他人完成本指南。
