跳转到主内容
Apple Studio Display M7649 ADC Cable Replacement
你所需要的
  1. Apple Studio Display M7649 ADC Cable Replacement, Stand: 步骤 1 中的图像 1,2 Apple Studio Display M7649 ADC Cable Replacement, Stand: 步骤 1 中的图像 2,2
    • Lay the display facing down with the stand away from you.
    • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
  2. Apple Studio Display M7649 ADC Cable Replacement, Panels: 步骤 2 中的图像 1,1
    • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
  3. Apple Studio Display M7649 ADC Cable Replacement: 步骤 3 中的图像 1,1
    • Rotate the display so the legs of the display are now facing you
    • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
  4. Apple Studio Display M7649 ADC Cable Replacement: 步骤 4 中的图像 1,1
    • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
  5. Apple Studio Display M7649 ADC Cable Replacement, Metal EMI Shield: 步骤 5 中的图像 1,1
    • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
  6. Apple Studio Display M7649 ADC Cable Replacement: 步骤 6 中的图像 1,1
    • Now locate and remove the lone Phillips screw holding the EMI shield to the display
  7. Apple Studio Display M7649 ADC Cable Replacement: 步骤 7 中的图像 1,2 Apple Studio Display M7649 ADC Cable Replacement: 步骤 7 中的图像 2,2
    • Now that the screw has been removed, slide the panel towards your body and lift it out.
    • You may need to remove the clear USB port cover to remove the metal EMI shield.
  8. Apple Studio Display M7649 ADC Cable Replacement, USB Port: 步骤 8 中的图像 1,1
    • To remove the USB port, remove these four screws holding down the port and metal brackets.
    • There may be a zip tie you need to cut that is attaching the USB unit to the display
  9. Apple Studio Display M7649 ADC Cable Replacement: 步骤 9 中的图像 1,1
    • Remove the cable from the logic board that is connecting the USB port.
  10. Apple Studio Display M7649 ADC Cable Replacement: 步骤 10 中的图像 1,1
    • Remove the USB port
  11. Apple Studio Display M7649 ADC Cable Replacement, ADC Cable: 步骤 11 中的图像 1,1
    • Remove these four screws holding down the base of the swing arm to the display and remove it
  12. Apple Studio Display M7649 ADC Cable Replacement: 步骤 12 中的图像 1,1
    • Remove the four screws holding down the ADC cable to the display
  13. Apple Studio Display M7649 ADC Cable Replacement: 步骤 13 中的图像 1,1
    • Remove the three connections that connects the ADC assembly to the logic board and screen
  14. Apple Studio Display M7649 ADC Cable Replacement: 步骤 14 中的图像 1,1
    • Remove and replace the ADC cable assembly.
结论
3等其他人完成本指南。
Andrew Tsao
于01/19/10注册
186 声望
创作了5篇指南
团队
Cal Poly, Team 3-20, Maness Winter 2010 Cal Poly, Team 3-20, Maness Winter 2010 的会员
CPSU-MANESS-W10S3G20
4 名成员
创作了15篇指南
一条评论
What are the two red wires and two black wires ?
Cali Red - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 24
总计 2,805
